Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Üdv Mindenki!
Van nekem régről 2db a fenti típusú hangszóróból és szeretném megtudni a Thiele-Small paramétereit.
Ha valaki segíteni tudna ebben azt megköszönném.
Más.
Valakinek nem lenne véletlenül a fiókjában elfekvőben kb.0,5m hangszóró membrán vezeték(?), mert a HS501-es mélyeim sajnos kontaktosak miatta.
Köszi
Üdv mindenkinek!
Javítanék egy TOYOTA CQ-XS0570 tip.autós Cd-t amiben optikát kellene cserélnem, viszont az eredetin a világon semmi jelzést nem látok.Tudna valaki ebben segíteni? Mi lehet a típusa?
kedvet kaptam a bakelit lemezhallgatáshoz. Ezért a padláson megkerestem szüleim Tesla GZC711-es lejátszóját, illetve találtam egy GZ711-et is. A kettő között csak annyi a különbség, hogy egyik sztereo, másik mono. Legalábbis ránézésre. Tű és
Hangszedő mindkettőbe VK4302 kell, de tű sajnos egyikben sincs már. Mivel új hangszedőt és és tűt már nem tudok ezekhez venni, érdemes használttal próbálkozni, ha találok? Illetve olvastam, hogy a kristály hangszedő nem is annyira jó a lemeznek, mert előbb tönkreteszi. Ezért azon is gondolkodom, hogy elengedem a Teslat és veszek valami mást. Találtam 80-as évekbeli Pioneert Pl 120 és 200-at, ami megtetszett, de nem tudom, ez is jó választás lenne-e. Mit javasoltok, merre kellene elindulni?
Annyi kiegészítést még tennék, hogy phono kimenettel erősítővel használnám. Eleinte meglévő régi lemezekkel, de szeretnék újakat is venni.
Köszönöm a segítséget előre is!
spgabor
