EM-TRAK I100 IDENTIFIER TRACKING TRANSPONDER SPANISH USER MANUAL
OTHER - USER MANUAL
1.3 MB
Looking for similar em manual?
    EMTRAK I-100 TRACKING SPANISH I100 IDENTIFIER 100 EM TRAK EM-TRAK
Yamaha KX-250 Cassettedeck output tick noise problem (electronic not mechanical)
There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
Pioneer CDJ-1000MK1 lemez olvasási probléma
Adott egy Pioneer CDJ-1000MK1 cd játszó. Olyan hibát produkál, hogy nem hajlandó beolvasni az írott cd-t, visszaköpi, viszont ha beleteszek egy gyári cd-t, azt beolvassa, majd miután kiveszem és újra próbálok beletenni írottat akkor már olvassa tökéletesen azt is, még a nagyon karcosakat is hiba nélkül. Viszont ha kikapcsolom és vissza, akkor megint nem olvassa. Ha eljátszom megint azt, hogy belerakok egy gyárit és utána írottat, akkor megint működik. Mi lehet a gond? Elvileg 1 éve volt fej cserélve, meg ha rossz lenne a fej, akkor egyáltalán nem olvasná az írottat.
Kapcsolóüzemű tápegység javítása. BTC03V0 - Alkatrész beazonosítása (megoldva)
Tisztelt Kollégák és Fórumtársak! Javításra került hozzám egy műszer amiben a tápegység modul tönkrement. A javítással már próbálkoztak mert az összes elektrolit kondenzátor ki van cserélve benne ill. a szokásos hibakeresésnek látszanak nyomai. Egy kicsi szerencsém volt mert azért szakmabeli lehetett aki a javításával próbálkozott, nincs semmi se összetaknyolva benne és korrektűl tette vissza a cserélt alkatrészeket. A hiba egyébként az volt, hogy nem indult be. Megvallom én is úgy voltam vele, hogy feladom de aztán megtaláltam a hibáját. Egy ellenállás volt szakadt amely az indításáról gondoskodik. Problémám az lenne - és ebben kérném a segítségeteket - hogy két kondenzátor a MOS-FET környékéről hiányzik. Ennek kellene a pontos értéke. Én ugyan pótoltam de nem tudom az értéke megfelelő-e. A táp jól működik de a FET és a képen látható 3k3/5W-s ellenállás nagyon melegszik. Szerintem ez nem rendeltetésszerű... Lehetséges, hogy a FET-t is cserélték, a típusát holnap megírom ide a fórumba. Kép a tápról:
MOS-FET környéke a hiányzó alkatrészekkel:
Táp alulról, beazonosításhoz:
Hiányzó alkatrészek: C7 és a C10 kondenzátorok értéke érdekelne:
Mint említettem jelenleg a táp működik. Jelenlegi állapotában a C10 helyére 470pF/2kV került; a C7 helyére 22nF/1kV-s került. Az értékválasztásban javítandó tápegységhez hasonló elektronikák kerültek megvizsgálásra és ez alapján döntöttem így... Sajnos nem találtam kapcsolási rajzot a tápegységről, sőt a javított műszer szervízkönyve is más felépítésű tápegységet ismertet. Nagyon köszönök minden segítséget! Megoldas: Kondenzatorok cserelve: C10: 330pF/2kV es C7:47nF/650V Melegszik meg mindig de a FET 45 fokon jar, az ellenallas se annyira forro mar, 50 foknal nem melegszik jobban fel. Mindez terheles alatt 24V/25W-s izzonal ket oranyi jaratast kovetoen. A tapegyseg 17V-t allit elo. Elnezest az ekezetnelkuli formaert de a munkahelyemrol irok!
ADE személymérleg (testelemző) nem mér, error hibaüzenetet ad
A mérleg elemcsere után is "Err" hibaüzenete ad; néha lehet lépkedni a menüben, de nem mér. Fürdőszobai, üveg felületű személymérleg, mindenféle test elemzést, súly, zsírszázalék, stb tudna. Gyártó WAAGEN-Schmitt GMBH, Art.no.:322984 Nagyon szétszedni sem lehet. Javítható, vagy kuka? köszönettel: roza
