ERRES BO400 BAND RECORDER MAGNETOFON 1965 SM
6.5 MB
Looking for similar erres manual?
    ERRES BO-400 RECORDER MAGNETOFON BO400 BAND 1965 BO 400
Yamaha CDX-590 laser adjustments?
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players. I have changed the laser unit (KSS-210A) but this didn't solve the problem. When I turn the player upside down, it plays the problematic CDs without a problem. That's why I think the laser needs adjustment. I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590. It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual. Here is a picture of the PCB. http://www.volny.cz/hwtest/PCB.JPG Here are the "test mode" sections of the service manual. http://www.volny.cz/hwtest/TM1.GIF http://www.volny.cz/hwtest/TM2.GIF In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one. So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode. It didn't help. Mode 1 - only a short blink of two horizontal dashes on the display and thats it Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on Mode 3 - seems to be very short as mode 1 I think I'm missing something ... Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser? Or maybe the problem is not the laser?
Sony STR-DB1070 protect felirat MEGOLDVA
Tiszteletem! Az említett erősítőt 2 napja hozták. Bekapcsolás után kis idővel a kijelzőn a "protect" felirat jelenik meg.Tápokat jónak mérem,végfokok nem zárlatosak.Szemrevételezéssel nem találtam rossz alkatrészt.Nincs nagy tapasztalatom az ilyen komoly erősítőkben, minden ötletet szívesen várok! Köszönöm! Üdv. Köszönöm az eddigi ötleteket!Ebbe az erősítőbe nem „hibrid” (pl:stk)végfok van hanem több kicsi tranyó.Így néz ki: http://dl.dropbox.com/u/10013794/strdb1070.JPG Megmértem a hangszóró kimeneteket,nincs kiugró eltérés feszültségben.Viszont feltűnt méregetés közben,hogy ha a speakers kapcsolót off-ba rakom,néha nem jön a protect felirat. Persze ha on-ra váltok egyből jön a felirat.Mivel ebbe az erősítőbe 3 db két áramkörös relével kapcsolgatják az összes hangszóró kimenetet,csak a relé előtt mértem.Fel is tűnt hamar hogy mindegyik relé forrasztásában hiba van.Átforrasztottam de a hiba nem változott. Múlt éjjel rávettem magam és átforrasztottam minden alkatrészt ami to-220 tok méretű vagy nagyobb egység.A hiba megszűnt,készülék lepróbálva,működik! Köszönöm mindenki hozzászólását! Üdv.
Philips radio
Aksi csere utan keri a kodot a radiom sorozatszam GM0201S1643372.ha valaki tud ebben segiteni,vagy valami hasznosat javasolni szivesen fogadom.Fizetek erte!
Philips 70FR330/00G magnója állandóan felvételre van kapcsolva
Egy Philips 70FR330/00g készülék magnó egysége (FC330) állandóan felvételen van. Ez egy kétkazettás deck, és az egyik fele kifogástalanul megy oda-vissza, a másik (B magnó) szintén hibátlanul csévél, de lejátszáskor csak fölvesz. Pontosabban: bekapcsoláskor a törlőoszcillátor azonnal elindul még akkor is, ha nincs lejátszásra kapcsolva, és töröl mindent.
Volna valakinek ötlete?
Köszönettel:
