Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Üdv! Volt már fent tavaly, de még időszerű: Asztalra került egy DSX700 Silverblade tip. erősítő, Ágotáéktól. Valószínűsíthető, hogy az egyik oldala zárlatra dolgozhatott, mert az egyik csatornában két FET, míg a tápban a két kapcsoló FET elhalálozott. Szeretném kérdezni, hogy van valaki itt a Fórumon, aki javított ilyen erősítőt és megosztaná a tapasztalatait. Különös tekintettel a rezonáns táphoz kéne iránymutatás. Köszönöm! Jani
Kaptam egy Technics SU-A900MK2 tipusú sztereó erősítőt. A hibája,hogy egyrészt az A kimenet működik , a B kimenet,ha hangszórót kötök rá, akkor alig tekerem fel a hangerőt, máris letilt az erősítő. A B kimeneti relé kikapcsol. Az előlapján minden kapcsolható. Hiányzik belőle a hűtő ventillátor is. Kérdezném,hogy ventillátornak jó-e 12v-os pc-be való? Kérdezném, hogy hol induljak el a rajz szerint.
Olvastad?
A címben jelzett mini hifin STBY van, viszont bekapcsolás után a hang megszólal majd teljesen leáll. Semmivel nem indítható a következő feszültség alá helyezésig. 3cd-s 1 fiókos rendszer,a hibát eleinte csak néha adta elő, mostanra viszont teljesen kuka lett. A cd része eléggé viharvert, elképzelhető, hogy nem áll pozícióba ezért old le? Hibát nem ír, jelöl. A gumik már rég elnyúltak benne, ezért nem gondolnék erre de hátha mégis. A tápjai jónak tűnnek, semmi nem melegszik, ami még érdekes, hogy stby-ban is megy a ventilátora. Ha esetleg valaki ismeri a gépet és tudna némi infót, megköszönném. Köszi a figyelmet !
