Grundig RRCD2420 mp3 tip. rádió, mp3 lejátszó rádió részével van gond, mert ugyan a kijelzőn látszik a hangolás de valójában csak egy adó szól bárhova is hangolnám a frekit. Tudna valaki segíteni? A TB2132FN IC-n megfelelő feszültségek mérhetők 6-os és 28-as lábakon: +3V. A 21-es lábon +6V.
Köszönöm:
tortuga
Trying to troubleshoot a issue with this radio and there are some SM / schematics on some websites,
but they are slightly different than this one.
Would anyone know a place to look where there are some Grundig people familiar with the products?
üdv: egy kis segítség kellene.
GM0200X6998746 és 02 00939 0330 699874 6 itt nálam 2292-vel indul.?
No:90 512 295
A másik:
GM0200V5472593 és 02 00939 0330 547259 3 itt kétségeim vannak.
No:90 462 562
1593 vagy 4623, vagy 6166 vagy valami más?
Kösz,
Hi All,
Does anyone have any experience of working on this radio, its the small Grundig with a leather case designed by F.A. Porsche.
I have recently repaired one with corroded battery contacts which had obviously not worked for many years.
Its now working perfectly on FM, but MW and SW1 and SW2 have no reception, just noise.
If I leave the radio connected to a 5v power supply for many hours it does actually get some reception on AM, but its not consistent. I'm thinking the fault is somewhere in the 'front end', oscillator stage perhaps.
I have checked the AM coils and wave selector switch are OK and everything is visually in excellent condition.
Reading various reviews on this radio confirms they were sold very cheaply in the USA and many customers have complained there is little or no sensitivity on AM, whilst others say it works perfectly. This makes me wonder if there is a common fault on these which someone may know, before I start with my test equipment to try to find the problem...
Any advice would be much appreciated!
