GRUNDIG HF 25 SM
8.5 MB
GRUNDIG HF 25 SM service manual (1st page)
Preview of GRUNDIG HF 25 SM [1st page]
GRUNDIG HF 25 SM service manual (2nd page)
Preview of GRUNDIG HF 25 SM [2nd page]
    GRUNDIG HF 25
Grundig YB-P 2000 not working on AM bands
Hi All,
Does anyone have any experience of working on this radio, its the small Grundig with a leather case designed by F.A. Porsche.
I have recently repaired one with corroded battery contacts which had obviously not worked for many years.
Its now working perfectly on FM, but MW and SW1 and SW2 have no reception, just noise.
If I leave the radio connected to a 5v power supply for many hours it does actually get some reception on AM, but its not consistent. I'm thinking the fault is somewhere in the 'front end', oscillator stage perhaps.
I have checked the AM coils and wave selector switch are OK and everything is visually in excellent condition.
Reading various reviews on this radio confirms they were sold very cheaply in the USA and many customers have complained there is little or no sensitivity on AM, whilst others say it works perfectly. This makes me wonder if there is a common fault on these which someone may know, before I start with my test equipment to try to find the problem...
Any advice would be much appreciated!
AUDI CONCERT 2 keyboard illumination (Grundig) k bus nélkül
Sziasztok! Nemrég kezembe került egy Audi Concert 2 autórádió. Sok minden info nincs róla a neten, de találtam egy oldalt, ahol a gombok világításával foglalkoznak, mivel az csak a K BUS csatlakoztatásával kapcsolható be. Ott bemutat egy megoldást, mely nem épp a legelegánsabb, de működő változat. http://www.audiworld.com/tech/elec86.shtml Nos, és tovább mentem, mivel az LCD kijelző megvilágítása működik, és ugyanaz a meghajtás, úgy gondoltam, közösítem. Eljutottam a processzorig, ahol két kimenet volt, egyik a gombok világítását kapcsolta, a másik az LCD-jét. Mivel 22kOhmon keresztül kapcsolta a tranzisztort, így biztos voltam benne, hogy egy kimenet elbírja mindkettőt. A készülék megvilágításra érzékeny, és nagyon szépen működik a világítás. A készülék egyébként úgy került hozzám, hogy semmit nem csinált. Mivel a processzoron megvolt minden tápfesz és a reset jel is magas volt, megmértem a kvarcot, és biza nem rezgett. Csere után elindult.
Radio magno Grundig car 2002
Udv mindenkinek, Egy kis segitseget szeretnek kerni a tisztelt kolegaktol. Egy Grundig Car 2002 auto radioba a kodot nem sikerul beirnom . Lehet hogy nem jol tudom a procedurat. Tudna valaki segiteni ebbe? Elore is koszonom.
Grundig WKC 5600 RDS ERROR1
Kedves Kollégák! Belefutottam a fenti készülékbe. A kijelzőn ERROR1 felirat virít. A legtöbb helyen a processzor eepromtartalmának hibájára utal, de hiába töltök bele bármit, nem változik a helyzet. A Tanyán fent van 3 bin fájl, szerintem mindegyik ugyanaz, egyikkel sem indlt. Van valakinek ötlete, esetleg bin fájlja? Üdv: Jácint
