GRUNDIG R520 RADIO SCH
92.4 KB
GRUNDIG R520 RADIO SCH service manual (1st page)
Preview of GRUNDIG R520 RADIO SCH [1st page]
    GRUNDIG R-520 R520 RADIO 520
Grundig zenegép trafótekercselés
Sziasztok! Kezembe került javítás céljából egy Grundig SO 200 zeneszekrény, aminek ég a trafója. Tud-e valaki egy olcsó, jó trafótekercselőt, aki lehetőletg Bp-en lakik. Az már hab lenne a tortán, ha Csepelhez közel volna. Köszönettel Attila
Grundig YB-P 2000 not working on AM bands
Hi All,
Does anyone have any experience of working on this radio, its the small Grundig with a leather case designed by F.A. Porsche.
I have recently repaired one with corroded battery contacts which had obviously not worked for many years.
Its now working perfectly on FM, but MW and SW1 and SW2 have no reception, just noise.
If I leave the radio connected to a 5v power supply for many hours it does actually get some reception on AM, but its not consistent. I'm thinking the fault is somewhere in the 'front end', oscillator stage perhaps.
I have checked the AM coils and wave selector switch are OK and everything is visually in excellent condition.
Reading various reviews on this radio confirms they were sold very cheaply in the USA and many customers have complained there is little or no sensitivity on AM, whilst others say it works perfectly. This makes me wonder if there is a common fault on these which someone may know, before I start with my test equipment to try to find the problem...
Any advice would be much appreciated!
Grundig UMS-5101 CDC mini torony, néha lehet csak bekapcsolni
Sziasztok! Valamelyik nap belehet kapcsolni, valamelyik nap nem, amikor bekapcsolódik akkor egész nap jó minden--ezt mondja a tulaj. Nekem nem sikerult még bekapcsolnom. Csak a piros stby led világít, display-en semmi nincs. Gomb megnyomásakor sem erôlködik ugyanugy világit a piros led. Van külön stby trafója ez ad +5V-ot, meg +10V-ot! ad 12V-os relé egyik lábára, a GND-t a relé másik lábára egy kis npn tranzisztor kapcsolja rá ha a processzor ad neki valoszinu +5V-ot, de 0V van a processzor MN101C15F kimeneti 52.lábán (POUT). A relé kapcsolja a nagy trafó primerjére a 230V-ot. A gombok jók- kilehet huzni a szalagkabelt és akkor 2Mohm-os határon is szakadás van. Gombok ellenállást kapcsolnak sorba az 5V-ra, a stby gomb 19kohm-ot kapcsol rá és 3.3V lesz amíg nyomom a gombot. Még nem mértem rá a kvarcra..
Grundig R2000
Üdv! Egy Grundig R2000-es került hozzám. Ismerősé, akit ráadásul érzelmi szálak fűznek a készülékhez, ezen kívül hölgy is az illető. A panasz az volt, hogy nem szól. Szétszedtem és hiányzott a 63V. A táp: A nyíllal jelölt biztosíték volt kiégve. Rövid méricskélés után nem találtam semmi különösebb problémát, így betettem egy 1.3 amperest (ilyen volt otthon, de mielőtt visszaadom veszek olyat mint ami gyárilag volt benne), bekapcsoltam és tökéletesen működik. Először arra gondoltam, hogy túlhajtották szegényt, de a végfokok tápját a 2x21V látja el. A biztosíték csere után járattam egy órát, semmi problémát nem tapasztaltam vele azóta. Mit gondoltok, merjem visszaadni? Azért dilemmázok, mert nem szeretném visszakapni egy hét múlva, a biztosítékok meg nem szoktak csak úgy kiégni... Rajz: http://elektrotanya.com/?q=showresult&megnev=grundig&megnev2=r2000gb&kategoria=&kat2=schematics DM
