HARMAN-KARDON MODEL-150 SM
3.3 MB
Looking for similar harman manual?
HARMAN-KARDON MODEL-150 SM service manual (1st page)
Preview of HARMAN-KARDON MODEL-150 SM [1st page]
HARMAN-KARDON MODEL-150 SM service manual (2nd page)
Preview of HARMAN-KARDON MODEL-150 SM [2nd page]
    MODEL-150 MODEL150 MODEL 150 HARMAN KARDON
Harman Kardon AVR 370 firmware kérés "megoldva"
Sziasztok! A fenti erősítőhöz keresnék szoftvert, akár lehet régebbi is. Ha valaki letöltötte és meg is őrizte esetleg.
May be useful - Harman Kardon information
For your information to repair Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown) can be changed without any other servicing Harman Kardon Receivers; Series AVR 2000,3000... "Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time. "Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V. "Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there. "volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V! "everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function. Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts. So i hope i can help you... cheers SG.
Harman Kardon HK980 processzor hiba
Adott a fenti erősítő, és odáig jutottam vele hogy valószínű hogy processzor hibás. SM5964C40JP típusú proci van benne, a hibajelensége hogy semmi életjel, ha a proci táp (5v) láb be van kötve akkor leesik 3v-ra a feszültség, ha lekötöm megvan az 5 volt. Ezért valószínűsítem hogy proci hiba lehet.
Kérdésem az lenne, hogy ez megoltható egy egyszerű proci cserével, vagy kell hozzá valami "célszoftver"  a procinak?
Harman Kardon AVR 151S - Nem lehet bekapcsolni
Hozzám került egy ilyen erősítő, ami áram alá helyezve semmire nem reagál, csak világít a stby led, és eléggé melegszik bent az stm proci, próbáltam uart-on olvasni a procit, de nem jártam sikerrel. lehetséges, hogy feladta az stm? Ha vennék másikat ahhoz meg nincsen program(legalábbis nem találtam sehol), vagy esetleg valakinek lenne hozzá mentése?
Üdv.: Viktor
