HARMAN-KARDON MODEL A-1040 TREND II SM
9.2 MB
Looking for similar harman manual?
HARMAN-KARDON MODEL A-1040 TREND II SM service manual (1st page)
Preview of HARMAN-KARDON MODEL A-1040 TREND II SM [1st page]
HARMAN-KARDON MODEL A-1040 TREND II SM service manual (2nd page)
Preview of HARMAN-KARDON MODEL A-1040 TREND II SM [2nd page]
    MODEL A-1040 II A1040 TREND 1040 HARMAN KARDON
May be useful - Harman Kardon information
For your information to repair Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown) can be changed without any other servicing Harman Kardon Receivers; Series AVR 2000,3000... "Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time. "Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V. "Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there. "volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V! "everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function. Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts. So i hope i can help you... cheers SG.
Harman Kardon mas-100 erősítő rca bemenet átalakitása/MEGOLDVA/
Sziasztok! Vásároltam a címben szereplő erősitőt. Sajnos a torony másik eleme/vezérlő/ nincs meg hozzá. Erősítő bekapcsol, mind a kettő oldal tőkéletes. Viszont a bemenete TLC081 el van megoldva Kérdésem az, hogy sima rca be menetet hogyan lehetne kialakitani? Üdv:atis76
Harman Kardon AVR161S "kivégzése"?
Sziasztok! Érdeklődnék, van-e értelme foglalkozni a javításával?
Történt, hogy az erősítő audio bemenetére rácsatlakoztattam egy régi összeeszkábált lemezjátszót, ami a bekapcsolása után leverte a kismegszakítót. Azóta az AVR kb. fél percig kapcsol be és nem ad hangot valamint a HDMI-n sem megy át a kép, egyébként látszólag működik, lehet váltani a bemenetek között csak a hangerőszabályzó nem reagál.
Elvittem a Cordon szervizbe, ahol egy nap után közölték, hogy alaplaphibás, kifutott készülék, nincs alkatrész, nem javítható.
A véleményeket előre is köszönöm: Lajos
Harman Kardon AVR 7500
Hey, i´m looking for a servicemanual for a harman kardon avr 7500 5.1 receiver. Does anyone of you have one? Or a owners manual? Or parts of this unit? If you have anything... pls give me a note! Thanks
