HARMAN-KARDON MODEL T-1040 THEME II SM
9.5 MB
Looking for similar harman manual?
HARMAN-KARDON MODEL T-1040 THEME II SM service manual (1st page)
Preview of HARMAN-KARDON MODEL T-1040 THEME II SM [1st page]
HARMAN-KARDON MODEL T-1040 THEME II SM service manual (2nd page)
Preview of HARMAN-KARDON MODEL T-1040 THEME II SM [2nd page]
    MODEL T-1040 II T1040 THEME 1040 HARMAN KARDON
Harman Kardon Avr151 230 táp hiba
Hello!
A fenti erősítő tápja megadta magát,
kicserltem mindent ami rossz volt,
már csak egy smd 6 lábu meghajtó
tipusára lennék kiváncsi ic92 pocicio számu.
May be useful - Harman Kardon information
For your information to repair Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown) can be changed without any other servicing Harman Kardon Receivers; Series AVR 2000,3000... "Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time. "Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V. "Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there. "volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V! "everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function. Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts. So i hope i can help you... cheers SG.
Harman/Kardon AVR65 RDS - Sudden Sound increase
Hello! Harman Kardon Receiver /amplifier AVR 65/RDS ! increases the Volume by it self some times (Suddenly) pse. advise .. Works Well otherwise! Best..Regards Rune..Sweden
Harman Kardon sub standby hiba?? MEGOLDVA!
Sziasztok! Auto standby-al lenne kérdésem. Adott két harman subláda, az egyik kb 10-12 perc után kapcsol ki, a másik viszont 30 perc után. Szokványos ez a jelenség vagy orvosolható-e, mi szabályozza a auto standby kikapcsolási időt?
