HISENSE TC-3400D-1-
TV - EPROM
887.0byte
EPROM
Looking for similar hisense manual?
    HISENSE TC-3400D-1 TC3400D1 TC 3400 3400D
Hisense H60N5705 automatically switches off
Dear all,
this TV, Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
The problem started to occur suddenly, during a video conference. It was switched on with the remote control, continued to work for a while and then switched off again.
The room technician changed the power cable (?), the HDMI cable (??) but the problem of course remained.
I asked if it changes anything by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
So they took the TV (a 60’ which is not easy to handle) to the lab and asked me to check it.
I still have to open it up, but I don't have the schematic diagrams and should proceed by trial and error, although I imagine a problem with the power supply stage.
How do you suggest I proceed, since I don't do TV but RF ?
Thank you for any help,
Best
Maximus
hisense 55a6g tv ragasztott kijelzőjének visszaragasztása
Üdvőzlök minden kedves kollégát. Azt kérdezném, hogy Ti milyen ragasztót használtok a ragasztott kijelző visszragasztásához, és mivel szeditek le a régi ragasztót ? Előre is köszönöm szives válaszaitokat.
Hisense PDH4217EU sm.
Üdv. mindenkinek! A Hisense PDH4217EU plazma tv szervízdoksiját keresem, de az LJ92-01200A panel rajza is segítene. Bontásból származó működő panel is érdekelne. Szép napot: majen
Hisense LED TV 55 INCH MODEL LEDN55K20DP MAIN BOARD RSAG7.820.5511/ROH dump ok
MODEL LEDN55K20DP
PANEL Hisense HD550DF-B31(010)/S1/FM
T-CON 14Y_EF11_TA2C2LV0.1
N55 SPI Flash  MX25L3205
