HISENSE TN-2155PLUS-1-
TV - EPROM
494.0byte
EPROM
Looking for similar hisense manual?
    HISENSE TN 2155 PLUS 2155PLUS
Hisense LED TV 55 INCH MODEL LEDN55K20DP MAIN BOARD RSAG7.820.5511/ROH dump ok
MODEL LEDN55K20DP
PANEL Hisense HD550DF-B31(010)/S1/FM
T-CON 14Y_EF11_TA2C2LV0.1
N55 SPI Flash  MX25L3205
Hisense H60N5705 automatically switches off
Dear all,
this TV, Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
The problem started to occur suddenly, during a video conference. It was switched on with the remote control, continued to work for a while and then switched off again.
The room technician changed the power cable (?), the HDMI cable (??) but the problem of course remained.
I asked if it changes anything by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
So they took the TV (a 60’ which is not easy to handle) to the lab and asked me to check it.
I still have to open it up, but I don't have the schematic diagrams and should proceed by trial and error, although I imagine a problem with the power supply stage.
How do you suggest I proceed, since I don't do TV but RF ?
Thank you for any help,
Best
Maximus
HISENSE LHD32A310JSEU LED TV Nem kapcsol be csak készenlét van.
Kedves kollégák! Fent nevezett TV T.MSD309.BA6S mainboard al van szerelve. Feltehetően SPI Flash tartalom hibás. Esetleg,ha lenne valakinek tartalom igen jól jönne.A http://remont-aud.net/dump/lcd_pdp_tv/blaupunkt/blaupunkt_32_126n_gb_5b_hbqkup_de_shassi_main_board_t_msd309_ba6s/380-1-0-44560 orosz oldalon van fent,hasonló main hoz de onnan nem tudok letölteni. üdv.
Hisense PDH 5039 stby-ba kapcsolás után néha villog a piros led
hi. a fenti típusú, működő saját plazmám-néha olyat tesz, hogy stby-ba kapcsolás után nem folyamatosan világít a piros led- hanem ütemtelenül (mintha kontakt hibás lenne!)villog!! de csak néha---általában stby-ba kapcsolás után kékről átvált pirosra. mostanában vettem észre és néhány órás működés után tett ilyet.. mi lehet a gyíkja??? valakinek van ötlete?? üdv: egon
