HOWARD RADIO CO. 468 SCH
99.8 KB
Looking for similar howard manual?
HOWARD RADIO CO. 468 SCH service manual (1st page)
Preview of HOWARD RADIO CO. 468 SCH [1st page]
HOWARD RADIO CO. 468 SCH service manual (2nd page)
Preview of HOWARD RADIO CO. 468 SCH [2nd page]
Studio 3000a erősítő
Tiszteletem! Az lenne a kérdésem, hogy ismeri-e valaki a fenti rémséget? A végfokba valaki bele babrált, és szeretném visszaállítani az eredeti állapotára.
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Panasonic SA-PT150 bekapcsolás után lefagy
Szisztok! Ez a házimozi bekapcsolás után beköszön(HELLO) majd a kijelzőn 5 vonal jelenik meg.Aztán nem csinál semmit gombra és távirányitóra sem. Volt már valakinek hasonló hibája? Köszi "FONTOS! Olyan fórum téma nevet válassz, ami beszédes, minél pontosabban illeszkedik arra, amivel kapcsolatban írsz. Egy lehetséges jó elnevezés pl: ORION LCD PT26S chassis 17MB12-2, a tápja nem indul Az nem elég, hogy pl: "LG LCD-TV" vagy "HP laptop" és hasonlóak. Illetve érdektelen, nem releváns információt se tartalmazzon a cím! A helytelenül elnevezett topik felfüggesztésre, majd 48 óra után törlésre kerül! Felfüggesztett állapotban nem tudnak mások addig hozzászólni, amíg ki nem javítod a címet. A hibás cím utólagos javítása (48 órán belül) a "Szerkesztés" fülre kattintva végezhető el."
service manual Sharp optonica SM-105
help me! I need a service manual SM-105 Sharp optonica my email address : trantai244@yahoo.com.vn
