KAPSCH TRIO-3G TUBES RADIO SCH
Type: (JPG)
299.5 KB
Looking for similar kapsch manual?
    KAPSCH TRIO-3G TUBES RADIO TRIO3G TRIO 3G
Yamaha CDX-590 laser adjustments?
I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players. I have changed the laser unit (KSS-210A) but this didn't solve the problem. When I turn the player upside down, it plays the problematic CDs without a problem. That's why I think the laser needs adjustment. I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590. It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual. Here is a picture of the PCB. http://www.volny.cz/hwtest/PCB.JPG Here are the "test mode" sections of the service manual. http://www.volny.cz/hwtest/TM1.GIF http://www.volny.cz/hwtest/TM2.GIF In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one. So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode. It didn't help. Mode 1 - only a short blink of two horizontal dashes on the display and thats it Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on Mode 3 - seems to be very short as mode 1 I think I'm missing something ... Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser? Or maybe the problem is not the laser?
JVC TD-V711 kazettás deck fluorenszcens kijelző hiba
Sziasztok! Adott egy JVC TD-V711 kazettás deck. Nagyon szép, megkímélt állapotban van. Egy gond van vele, a kijelzője nagyon összevissza müködik. A fluoreszcens kijelző bal oldala ott is világít, ahol nem kellene, a jobb oldala viszont nagyon-nagyon halvány. Itt a tanyán fent van a kapcsolási rajz, Az 5V AC fűtőfeszültséget megkapja a kijelző. A feszültség enyhe növelésével a kijelző erősebben világít, viszont egyik oldala ugyanúgy halványabb, a bal oldalán pedig ugyanúgy világítanak olyan szegmensek, amelyeknek nem kellene. Lehet ha ki van öregedve a kijelző? Miket nézzek még esetleg meg, merre tapogatózzak? Esetleg tud valaki segíteni ilyen bontott kijelzőt találni? Endre
Laney WS 80R erősítő
Ehhez a gitár erősítőhöz keresek valamilyen leírást,egyáltalán mit csinál.Az erősítésen kívül milyen funkciói vannak.Esetleg némi dokumentáció is érdekelne.Bármilyen segítséget szívesen vennék.
AR 612 skálahúrozás rajzát keresem
Se nem hifi, se nem erősítő, de azért jó kis rádió volt a Pacsirta AR 612. Hátha azért elfér ebben a rovatban...
Behoztak egy Pacsirtát, ami romokban hevert. A skálahúrozás(ok) rajzára lenne szükségem, ha valakinek megvan. Amelyik Kádár-könyvemben van kapcsolási rajz, abban nincs a skálahúrokhoz rajz, és sajnos az egér és az idő alapos munkát végzett. Megköszönném, ha valaki tudna segíteni.
Üdvözlettel:
