KENWOOD DP-7040
5.7 MB
KENWOOD DP-7040 service manual (1st page)
Preview of KENWOOD DP-7040 [1st page]
KENWOOD DP-7040 service manual (2nd page)
Preview of KENWOOD DP-7040 [2nd page]
    KENWOOD DP-7040 DP7040 DP 7040
Request for Firmware or Help – Kenwood M-9000 SS stuck on "Waiting for PC Wizard"
Hello,
I recently purchased a used Kenwood M-9000 SS micro Hi-Fi system, but unfortunately, the unit is not functioning correctly. When I power it on, the display is stuck on the message "Waiting for PC Wizard", and the device becomes completely unresponsive – it does not react to any buttons or remote control inputs.
From my research, it seems that this issue may be caused by a missing or corrupted firmware, particularly related to the Sunplus SPHE8202 chipset used inside the device.
I have been trying to locate the correct firmware file (possibly DVDROM.BIN) that matches the hardware (the board ID may be BD305890BB9B50), but so far, I have had no luck finding a working download source.
Could someone please help me with:
  • The correct firmware file for this model
  • Instructions or guidance on how to recover the system using a USB flash drive
  • Any experience with solving this "Waiting for PC Wizard" message on similar Sunplus-based systems
Any help or direction would be greatly appreciated!
Thank you in advance.
Best regards,
Dejan Todorović
KENWOOD KA 1100D erősítő DC offset hiba
Üdvözletem mindenkinek, a fent említett erősítövel nem tudok düllőre jutni. Ugyanis, a jobb csatornán kb -8V fezsültség van a kimeneten, persze a védelem nem kapcsolja a relét (még jó), a bal csatorna OK. Első pillantásra nem nézett ki komplikált esetnek viszont most beletörtem a fogamat. A kimenőtranzistorokat lekapcsoltam mindkét csatornán és csak az A osztály működik. Letöltöttem a KENWOOD KA 1100SD SM-et, de sajnos a kapcsolási rajz nagy mértékben eltér a KA 1100D-töl, úgyhogy jóformán használhatatlan. A TA7030 feszűltségerősítő hibrid IC-ket felcsréltem, a hiba maradt ugyanazon a csatornán. A bemenőfokozatban a FET inegrált differenciálokat is felcseréltem, de semmire nem jutottam vele. Minden tranzistort kivizsgáltam komponent teszterrel és hajszálegyformák a grafikák mindkét csatornán. Mivel nem tudok tovább lépni kapcsolási rajz nélkűl, a WANTED-be tettem, ha valakinek az 1100D kapcsolási rajza megvan, legyen szíves, töltse fel. további sikeres munkát
Kenwood KX-7030 deck fl kijelző nem egyforma fényerővel világít.
Üdv mindenkinek. Adott a címben szereplő deck kijelzőjének szegmensei nem egyforma fényerővel világítanak.A kivezérlésjelző pálcikái jól a többi elem meg halványabban, tudnátok tippet adni mi lehet a baj. Előre is köszi.
Kenwood KRF V5030D enkóder típusa!MEGOLDVA!
Sziasztok! Az lenne a kérdésem,hogy a fent nevezett erősítőben kellene cserèljem a hangszínszabályozó encodert! A gyártója az meg van ALPS gyártmány,csak a pontos tipusát nem találom még a rajzon sem! Ha valaki tudja legyen szíves írja le! Előre is köszönöm!
