If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Hello,
I recently purchased a used Kenwood M-9000 SS micro Hi-Fi system, but unfortunately, the unit is not functioning correctly. When I power it on, the display is stuck on the message "Waiting for PC Wizard", and the device becomes completely unresponsive – it does not react to any buttons or remote control inputs.
From my research, it seems that this issue may be caused by a missing or corrupted firmware, particularly related to the Sunplus SPHE8202 chipset used inside the device.
I have been trying to locate the correct firmware file (possibly DVDROM.BIN) that matches the hardware (the board ID may be BD305890BB9B50), but so far, I have had no luck finding a working download source.
Could someone please help me with:
The correct firmware file for this model
Instructions or guidance on how to recover the system using a USB flash drive
Any experience with solving this "Waiting for PC Wizard" message on similar Sunplus-based systems
Any help or direction would be greatly appreciated!
Thank you in advance.
Best regards,
Dejan Todorović
