Good afternoon!
I'm looking for a dump for the LG PF1000U projector (chassis FM51E), (NAND Hynix H27U1G8F2CTR SPI_FLASH: MX25L8035EM2I, EPROM 24C256C).
There is no epk file available anywhere :(
This device attempts to turn on and responds to both buttons and the remote control:
It exits standby, runs the fans for 5 seconds, then spins them at 100% for another 5 seconds judging by the sound, and then goes back into standby.
The problem seems to be a corrupted NAND as it appears to me:
[ 0.110000] NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3.3V 8-bit)
[ 0.110000] redirect_size = 400000, redirect_start = 7c00000
[ 0.110000] Loading nand bad block info(00000000+00020000)...
[ 0.119000] Mstar nand-flash partition definition
[ 0.119000] mtd info: # of partitions = 23
[ 0.119000] Creating 23 MTD partitions on "NAND 128MiB 3.3V 8-bit":
[ 0.119000] 0x00000000-0x00020000: "bbminfo"
[ 0.120000] 0x00040000-0x00060000: "mtdinfo"
[ 0.121000] 0x00160000-0x00760000: "rootfs"
[ 0.121000] 0x00760000-0x007c0000: "lginit"
[ 0.122000] 0x007c0000-0x007e0000: "crc32info"
[ 0.123000] 0x007e0000-0x00800000: "model"
[ 0.124000] 0x00800000-0x00900000: "logo"
[ 0.124000] 0x00900000-0x00a00000: "cmndata"
[ 0.125000] 0x00a00000-0x01200000: "nvram"
[ 0.126000] 0x01200000-0x01300000: "user"
[ 0.127000] 0x01300000-0x01400000: "ezcal"
[ 0.128000] 0x01400000-0x014a0000: "estream"
[ 0.128000] 0x014a0000-0x01620000: "opsrclib"
[ 0.129000] 0x01620000-0x018a0000: "kernel"
[ 0.130000] 0x018a0000-0x03560000: "lgapp"
[ 0.131000] 0x03560000-0x04fa0000: "lgres"
[ 0.132000] 0x04fa0000-0x05be0000: "lgfont"
[ 0.132000] 0x05be0000-0x05c00000: "tplist"
[ 0.133000] 0x05c00000-0x07640000: "lgres"
[ 0.134000] 0x00080000-0x000a0000: "cert"
[ 0.135000] 0x000a0000-0x00140000: "authcxt"
[ 0.136000] 0x00060000-0x00080000: "hdcp2"
[ 0.137000] 0x00140000-0x00160000: "keyrsrv"
[ 0.138000] mod_nand_init is invoked
[ 0.138000] GE driver inits
[ 0.138000] mod_iic_init is invoked
[ 0.138000] model option = 0xfc
[ 0.138000] Mstar_emac: [PHY Addr] ==> :0
[ 0.138000] Mstar_emac: alloRAM_VA_BASE = 0xA0C40000 alloRAM_PA_BASE= 0xC40000 alloRAM_SIZE= 0x100000
[ 0.139000] RBQP_BASE = c44000
[ 0.140000] [SCALER][000173] _mod_scaler_init
[ 0.140000] [TTX_DRV][00508]init 170
[ 0.140000] MDrv_CC_Init
[ 0.140000] init 172
[ 0.140000] [DEMOD_DRV][00369]init 245
[ 0.140000] [BDMA_DRV][00629]init 251
[ 0.141000] TCP cubic registered
[ 0.141000] NET: Registered protocol family 17
[ 0.142000] RPC: Registered udp transport module.
[ 0.142000] RPC: Registered tcp transport module.
[ 0.142000] Adding user_initcall[0] = 0x803a1314
[ 0.142000] Adding user_initcall[1] = 0x803a1320
[ 0.142000] Adding user_initcall[2] = 0x803a66f8
[ 0.144000] VFS: Mounted root (squashfs filesystem) readonly.
[ 0.150000] VFS: Mounted lginit (squashfs filesystem) readonly.
[ 0.150000] Freeing unused kernel memory: 132k freed
[ 0.204000] SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock19
[ 0.225000] Empty flash at 0x000213bc ends at 0x00021800
[ 0.234000] Empty flash at 0x00023200 ends at 0x00023800
[ 0.242000] Empty flash at 0x00024bbc ends at 0x00025000
[ 0.250000] Empty flash at 0x000271ec ends at 0x00027800
[ 0.250000] jffs2_scan_inode_node(): CRC failed on node at 0x00028fe0: Read 0xffffffff, calculated 0x916f9a2e
[ 0.258000] Empty flash at 0x00029120 ends at 0x00029800
[ 0.264000] Empty flash at 0x0002ab84 ends at 0x0002b000
[ 0.289000] Empty flash at 0x00040878 ends at 0x00041000
[ 0.289000] jffs2_scan_dirent_node(): Node CRC failed on node at 0x000427f4: Read 0xffffffff, calculated 0x2322e93d
Thank you in advance!
Segítséget szeretnék kérni hátha valaki már találkozott ezzel vagy hasonló alkatrésszel.
Szóval adott egy LG Multisplit Klíma vezérlő. Ezen a vezérlőn van a készenléti tápegység PTC biztosítéka
ami tönkrement. Csakhogy sem az alkatrészt sem a gyártót és az értékét sem sikerült kideríteni.
A PTC-nek van egy hőálló bakelit tokja amibe be van csúsztatva egy 14mmm átmérőjű 3mm vastag gombelemre elékeztető
betét. A fedélen a felirat felső sor.: 400X Alsó sor.:KSR12
Behelyettesíteni csak akkor szeretném ha biztosan nem lehet beazonosítani mivel a vezérlő tápja elég rafináltan,
szerintem feleslegesen bonyolultan működik.
Ugyanis a PTC a teljes főáramba van bekötve ha a klíma bekapcsol abban az esetben van vele párhuzamosan egy relé,
ami ha meghúz megkerüli a biztosítékot és az áramot pedig egy mérőtranszformátoron keresztül méri (Borzalmasan agyonbonyolított)
Szóval megköszönném ha valakinek lenne ötlete ezzel a ptc-vel kapcsolatban.
Kép mellékelve.
Köszönöm
Tisztelt szakik!
A címben említve a lényeg! Elöljáróban: a készülék korábban valami löttyel le lett öntve(kikapcsolt állapotban) próba után a master ledkijelző csinált hülyeségeket, de kontaktspré folyatásával a lötyimaradék a látható/vélhető aláfolyt helyekről le lett pucolva- kijelző bibi megszünt. továbbá a fejhallgatóból több is ki lett próbálva és másiknál is csinálja, a hangerejét lehet szabályozni de halkan-hangosan is torz. a készülék várhatóan jövőhét végén kerül hozzám, addig én ennyit tudok!A kapcsrajz itt a honlapon megvan, töltöm és átnyálazom!
Vélemény?
Segítségre lenne szükségem.A fent nevezett töltőt bedugtam,hogy töltöm az akkukat de nem történt semmi.Csak ciripelést hallani.Szétszerelés után láttam,hogy kapcsolóüzemű táp van benne.Szükségem lenne kapcsolási rajzra vagy tanácsra,hogy mit cseréljek.Púpos kondikat nem láttam.
Előre is köszönöm.
Tisztelettel:Geri100
