Preview of LG 60LB6500-UP CHASSIS LA42B 1403-REV00 [1st page] Click on the link for free download!
Preview of LG 60LB6500-UP CHASSIS LA42B 1403-REV00 [2nd page] Click on the link for free download!
Download free of charge (10 files / day): Download processing...
Also known:
LG CHASSIS LA-42B 60LB6500UP LA42B 1403REV00 60 LB 6500 UP LA 42 1403 REV 00 60LB6500 REV00 1403-REV00
If you have any question about repairing write your question to the Message board. For this no need registration.
If the site has helped you and you also want to help others, please Upload a manual, circuit diagram or eeprom that is not yet available on the site. Have a nice Day!
Warning! If you are not familiar with electronics, do not attempt to repair! You could suffer a fatal electrical shock! Instead, contact your nearest service center!
Note! To open downloaded files you need acrobat reader or similar pdf reader program. In addition,
some files are archived, so you need WinZip or WinRar to open that files. Also some files are djvu so you need djvu viewer to open them.
Hi everybody, my first post here.
I've found on this site many information and the service manual about the TV in subject, but I stumbled upon a strange issue.
I repaired the earphone socket (pic attached) that had been stripped away and now the TV doesn't power on, it only gives a short beep when you touch the power on button and nothing happens using the remote. I checked the usual things (audio paths, cracked solderings, damaged tracks, power supply, power rails), but I cannot found what's wrong.
Any idea/clue on what to (double) check this time?
Itt van a fent említett csoda tv, amin a tuner mama aljzatot elhajlították valahogy. A meleg pont lötyög az egész házban, de a forrasztás nincs kiszakadva. A külső része pedig kb 45 fokban balra hajolt, amit ha visszahajlítok lehet le is törik a házról, a hátlapot úgy beszorította, hogy szó szerint szét kellett feszíteni, hogy lejöjjön. A legnagyobb probléma, hogy a tulaj mindenképpen tunerről szeretné használni, csak ilyen állapotban meg rendetlenkedik a vétel. Szolgáltatójától CI kártyával jön a digit adás.
Ajánlottam neki a HD beltérit, így kiesne a tuner, de nem akar pluszban még azért is fizetni, mert már egy van, 2. pedig fizetős.
Mit csináljak vele? :D Gari már lejárt, esetleg megkérdezzem az LG szervizt, hogy tudnak-e ilyen házat küldeni?
Udv a tanyazoknak!LG42PJ550N tipusu plazma kerult hozzam hianyos Z-sus modullal.Z-sus model EAX61420601;Q202,Q203,Q205,Q206 hianyzik.Gyanus hogy a PDP lehet hibas de egy probat megerne.Minden infot elore is koszonok.
Tisztelettel:Rakoczi
If you want to join us and get repairing help please sign in or sign up by completing a simple electrical test or write your question to the Message board without registration. You can write in English language into the forum (not only in Hungarian)!
