Preview of LG PDP42V7 SM [1st page] Click on the link for free download!
Preview of LG PDP42V7 SM [2nd page] Click on the link for free download!
Download free of charge (10 files / day): Download processing...
Also known:
LG PDP-42V-7 PDP42V7 PDP 42
If you have any question about repairing write your question to the Message board. For this no need registration.
If the site has helped you and you also want to help others, please Upload a manual, circuit diagram or eeprom that is not yet available on the site. Have a nice Day!
Warning! If you are not familiar with electronics, do not attempt to repair! You could suffer a fatal electrical shock! Instead, contact your nearest service center!
Note! To open downloaded files you need acrobat reader or similar pdf reader program. In addition,
some files are archived, so you need WinZip or WinRar to open that files. Also some files are djvu so you need djvu viewer to open them.
HELO mindenkinek segitseget kerek tolletek plazma tv javitasban van hang nincs kep az Y sus on volt egy nagy condi felrobbanva a VS tapon meg a bistositek elegve , kicsereltem elinditom a tv-t kisult az egyik AN xxxxx buffer chip azt csak kivettem es igy probaltam beinditani lenyegeben kellene mukodnie egy chikkal a kepernyon , vagy nem ?
van VS VA 5V 15V reagal a kepernyo ha piszkalon bealitasokat az Y SUS on es Z-n is
Eszrevetelek nem mindegyik MOSfet blokkok melegsenek be az Y-en 5 hutobordabol csak 3 mekegszik a Z n 3 bol csak 2 melegszik a buffer chippe hidegek van skop-om de nem tudom mit kellene ellennorizni egy Y board-on van egy van e valami gyorskepzo leiras vagy video ?
A main-bol skoppal mertem video jelet az van
vajon eszleli hogy hianyzi e buffer chip
elore is kosz ha segit valaki
Hi everybody, my first post here.
I've found on this site many information and the service manual about the TV in subject, but I stumbled upon a strange issue.
I repaired the earphone socket (pic attached) that had been stripped away and now the TV doesn't power on, it only gives a short beep when you touch the power on button and nothing happens using the remote. I checked the usual things (audio paths, cracked solderings, damaged tracks, power supply, power rails), but I cannot found what's wrong.
Any idea/clue on what to (double) check this time?
A fenti gépnek egyik napról a másikra aHDMI benetről eltűnt a képe.
Kábelhiba kizárva, több jelforrásról kipróbáltam a hiba ua.
Ehhez kérném a segítségeteket.
Köszönettel: Laci
If you want to join us and get repairing help please sign in or sign up by completing a simple electrical test or write your question to the Message board without registration. You can write in English language into the forum (not only in Hungarian)!
