MARANTZ BD7003
VIDEO-DVD - SERVICE MANUAL
19.5 MB
MARANTZ BD7003 service manual (1st page)
Preview of MARANTZ BD7003 [1st page]
MARANTZ BD7003 service manual (2nd page)
Preview of MARANTZ BD7003 [2nd page]
    MARANTZ BD-7003 BD7003 BD 7003
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
KERESEK Panasonic NV-FS88 vagy FS200-ba való VEH0467 típusú fejet
Ha valakinek lenne elfekvőben (emberi áron) Panasonic FS88 FS90 FS200 -ba való VEH0467 típusú feje az jelezzen.
Köszönöm
Peti
ORION VH-2901 videó RF-en nem ad jó képet
A címben szereplő videóba megy a UPC kábel, majd RF-en tovább a TV-hez. Egy ideje a videó az RF kimenetén egy fekete-fehér, borzasztóan szemcsés képet ad. (Mint amikor törött a koax kábel. De nem az.) A felvétel tökéletes. A TV nincs elhangolva. Ami furcsa: - Ha kazetta lejátszásnál kihúzom az antennakábelt, akkor jó lesz a kép - Euro-AV kimeneten akkor is szép képet ad, ha nem húzom ki az antennakábelt Lehet vele élni, de jobb volt, amikor nem kellett kábeleket húzogatni... Mi történhetett ezzel?
SONY VCR
SZiasztok Van egy Sony SLV363EE videóm.A capstan motorja 2-3mp-ként megáll egy pillanatra.A hozzászólásokat előre is köszönöm.
