MARANTZ DV9500 MZ06-023
VIDEO-DVD - INFO-TIPS
131.0 KB
INFO-TIPS
MARANTZ DV9500 MZ06-023 service manual (1st page)
Preview of MARANTZ DV9500 MZ06-023 [1st page]
MARANTZ DV9500 MZ06-023 service manual (2nd page)
Preview of MARANTZ DV9500 MZ06-023 [2nd page]
    MARANTZ DV-9500 DV9500 MZ06023 DV 9500 MZ 06023 MZ06 023 MZ06-023
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Philips VR410/58-elfelejti a dátumot
Üdv! Olyat tesz a gép, hogy kb félorán belül visszaáll a beállitott dátum , ill. csak az év 2099-re, óra, nap-honap megmarad. Ha beállitom és kihuzom akár tiz perc mulva is marad minden a helyén, később ránézve egyszercsak 2099-et ir ki, és nem lehet észrevenni mert az óra jot mutat. Időzitett felvételre használnák azért volna fontos, kontakthibát nem találtam, hidegre-melegre nem érzékeny, merre induljak?
Panasonic NV-SJ 207EE nem talál adókat
Sziasztok! A fent említett video hangolásnál nem talál adókat . A tápokat ellenőriztem , a 30V is megvan. Volt , hogy talált, de elfelejtette aztán őket. Előfordulhat a tuner hiba is , esetleg ha valakinek lenne bontásból arra vevő lennék . ENG57808G1 a tipusa Köszi Laci
GPX VCD1240 DivX VIDEÓ DVD kombó fejhibás? (MEGOLDVA)
Sziasztok! A fenti szerkezet videója a saját felvételeit jól játsza le,de másik magnóban már nem, illetve az idegen felvételeket is tracking hiba szerűen játsza le. Az önteszt fejhibát ír ki ilyenkor. Ismeri valaki ? Üdv: Wolf
