NEO TV2177TXKIK
TV - EPROM
Type: (BIN)
1024.0byte
EPROM
Looking for similar neo manual?
    NEO TV 2177 TXKIK
Neo TV 1425
Hoztak hozzám egy Neo tv-ét.A képernyő kék,balról egy piros lakat van.Megpróbáljam az eepromot kicserélni,ki tud segíteni/előre is kösz.
NEO TV-2132TX.
eeprom tv NEO TV-2132TX..procesor:TDA9352PS.N2.3I
LED TV NEO LED-2202FHD It does not work, the front LED off ,power supply is OK
Mark:NEO LED-2202FHD
Model:LED-2202FHD
Chassis (main board, components): 17MB60-3 flash 25Q80
LCD Screen/Panel :: LC215EUN (SC) (A1)
More informations:   Power supply 17PW05-2
   _SN : 6694377 100624
It does not work, the front LED off, the power supply is ok.It was software on usb several times, periodically every 2-3 months and it worked, finally it was left with the st.by LED off, that's why I-m thought about flash memory. Thanks a lot!
TV Neo 2159TX
Sziasztok Nem tudja valaki ,milyen taviranyito talal ehez atv-hez Koszi
