Sziasztok. A cimbeli erolkodovel kuzdok, a problema a kovetkezo: ha az FM mute aktiv (on), nem talal adot, ha kikapcsolom, az automata keresovel nem talal adot, de kezi keresessel bejonnek az adok, es memorizalni is lehet oket. Ha valaki erti hogyan mukodnek ezek a dolgok, kerem adjon nehany tanacsot. Koszonom.
Hello!!
Ha valaki el tudná nekem küldeni az Onkyo Tx-7430 erősítő kapcsolási rajzát nagyon megköszönném :)
I have a Onkyo DX-7333 CD player, which sometimes doesn't recognize CDs.
I don't think it's a laser pickup (KSS-213C) problem, because when it recognizes the CD, it plays it without a problem, even very scratched ones.
The next thing is, it should play CD-RWs, but it doesn't even recognize them.
I think it needs adjustment
There are two pots on the main PCB - Focus Gain R123 and Focus Offset R112.
Also there are two test points:
TP1 4 pins, first pair labelled Tracking Gain, second pair Focus Gain
TP2 2 pins labelled RF Out and VC
But in the service manual is no description, what should be measured on the test points and how to set Focus Gain and Focus Offset.
In the attachment is a cut out from the schematic, where the test points and adjustment pots are.
Please if someone knows, how to?
Sziasztok. Hibasan vettem egy Onkyo Tx8410r tipusu radios erositot. A hangsugarzovedo relei voltak hibasak. A bajom most az, hogy a 2 savos hangszinszabalyzoja igencsak sovany tartomanyban fejti ki hatasat, jo esetben talan +- 2 dB-t erosit/vag. Ezt szeretnem elfogadhato mertekre tornazni fel, es ebben kerem a segitsegeteket merthogy en ehhez mar nem ertek. SM van fenn a Tanyan. Udv.
