OROSZ USSR FERARI-1.
CAR-AUDIO - SERVICE MANUAL
95.1 KB
CAR-AUDIO
Looking for similar orosz manual?
    OROSZ USSR FERARI-1. FERARI1. FERARI 1.
Ford 6000cd lezárták
Agyatlanok akku csere után addig próbálkoztak amíg lezárta magát a kèszülèk.
Locked 13
Van a kijelzőn. A gyári kódja megvan csak nem tudták hogyan kell beállítani. Mit lehet ilyenkor tenni?
Köszönöm Laci
Becker Cascade BE7944 need help!
Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
 I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Mazda Premacy CB01669C0 autórádió Aux bemenet aktiválása
Jó napot!
Adott a címben említett autórádió. Kérdésem az lenne, hogy megoldható-e valamilyen átkötéssel az Aux aktiválása, vagy csak Cd tár rákötésével válik használhatóvá. Amit eddig találtam, azok közt nem volt eredményes megoldás.
Find a Mercedes-Benz 221 amplifier drawing
Find a Mercedes-Benz 221 Harman Kardon L7 large offensive and defensive technical drawings, small amplifier technical drawings are also needed, can technicians with the above technical drawings share it? If you can, you can send me a private message or WTSN@QQ.COM email, I am engaged in full-time maintenance of car audio navigation products in China.
A221 900 81 03 ZGS
A221 820 52 89  (MR1510)
