PANASONIC DMC-GX7KP KPC KEG KGN XXX DIGITAL CAMERA
STILL CAMERA - SERVICE MANUAL
16.1 MB
STILL CAMERA
PANASONIC DMC-GX7KP KPC KEG KGN XXX DIGITAL CAMERA service manual (1st page)
Preview of PANASONIC DMC-GX7KP KPC KEG KGN XXX DIGITAL CAMERA [1st page]
PANASONIC DMC-GX7KP KPC KEG KGN XXX DIGITAL CAMERA service manual (2nd page)
Preview of PANASONIC DMC-GX7KP KPC KEG KGN XXX DIGITAL CAMERA [2nd page]
    PANASONIC DMCGX-7KP KPC KEG KGN XXX DIGITAL CAMERA DMCGX7KP DMCGX KP DMC GX7KP DMC-GX7KP
Panasonic NV-RX67EG/E VHS-C kamkorder nem mindig számlál
Üdvözletem! A fenti kamera pörgetéskor nem mindig számlálja a műsoros részeket. Elmondás szerint volt, hogy nem vett fel jól, ezt nem tudtam reprodkálni, nálam a felvett anyag minősége jó. Milyen irányban érdemes elindulni a hibakereséssel? Tisztelettel: Horváth József
Panasonic GH5 Viewfinder Repair - Issue: No switch on
initialy the GH5 viewfinder (LVF) would not display anything when I looked through it, indicating a possible issue with the power supply or the internal connection to the viewfinder circuit. So i Opened the camera and inspected the flexible ribbon cable connected to the viewfinder PCB.
  • Identified a potential problem with the FPC connector, which appeared loose and damaged at the pin connection points.But i resolder it.
  • And i Tested the continuity of key components the power board,even the flex cable by cotinuity.
  • After that, testing, the device did not power on at all, even after check the ribbon cable and ensuring the battery was functional.i have 3 diffrents.
  • Currently i'm thinking on check if  the power board (DC-in connector) has a short circuit or other internal faults that might have caused the system failure
    Does someone can confirm which part i have to test and which component maybe ?
    Can anyone confirm which specific components I should test further?
    Thank you!
Panasonic DMC-LS1 fényképező új elemmel sem megy
Sziasztok! Ezt a gépet szüleim vették 2005-ben, azóta folyamatosan ment :) A probléma szerintem folyamatosan egyre rosszabb lett, miszerint ma már ha új elemet teszek bele, akkor is azt írja lemerült. Ez a szokásos zárlat lehet, több fényképező is csinálta, visszaemlékezve fórumtopikokra. Nos én meg tudom itthon csinálni? Átvezető smd vagy hasonló lehet a rossz benne? Köszi! Üdv: Pityesz
Panasonic NV-DS77 mini DV kamera
Sziasztok Van egy Panasonic NV-DS77 es tipusú mini Dv kamerám aminek nem működik a DV kimente sajna a csatlakozónál az érinkezők sérültek . Azt kérdezném hogy ilyen panelba forraszthatós DV csatlakozót belehet e szerezni valahol?
