A tévé nem ad hangot. Egyik bemenetről sem. Letöltöttem a szervizkönyvet, és
" Service Modes, Error Codes, and Fault FindingEN 12 TCM2.0E LA5.
5. Service Modes, Error Codes, and Fault Finding
Index of this chapter:
5.1 Test Points
5.2 Service Modes
5.3 Error Codes
5.5 Service Tools
5.1 Test Points
This chassis is NOT equipped with test points in the service
printing. No test points are mentioned in the service manual.
5.2 Service Modes
The Service Mode feature is split into different parts:
• Service Alignment Mode (SAM).
• Service Default Mode (SDM).
• Customer Service Mode (CSM).
SDM and SAM offer features, which can be used by the Service
engineer to repair/align a TV set. Some features are:
• Activates the blinking LED procedure for error identification
when no picture is available (SDM).
• Make alignments (e.g. white tone), (de)select options,
enter options codes, reset the error buffer (SAM).
• Display information (“SAM” indication in upper right corner
of screen, error buffer, software version, options and option
codes, sub menus).
The CSM is a Service Mode that can be enabled by the
consumer. The CSM displays diagnosis information, which the
customer can forward to the dealer or call centre. In CSM
mode, “CSM”, is displayed in the top right corner of the screen.
The information provided in CSM and the purpose of CSM is to:
• Increase the home repair hit rate.
• Decrease the number of nuisance calls.
• Solved customers' problem without home visit.
5.2.1 Service Alignment Mode (SAM)
How to Enter
To enter SAM, use the following method:
• Press on the remote control the code “062596” directly
followed by the “INFO” key.
After entering SAM, the following screen is visible, the values
can be adjusted according to the requested (see Chapter 8"
Szóval a saját távirányítóján az INFO gomb helyén időzítő óra jele látható. Ha beütöm a 062596 kódot, az első két szám után jön az üzenet, hogy nincs ilyen csatorna, de ha nem hagyom abba, és végig nyomom a 6 számjegyet, majd az INFO gombnak megfelelőt. (Megkerestem a képét a NET-en) akkor sem lép be.
Van valakinek ötlete, vagy más kódja?
Előre is köszönöm!
T.
Sziasztok! A fent nevezett tv-hez kérek javítási tanácsokat. A hiba jelenség: ki veri a biztit, és a táp meghajtó tranyó (ON 4827, cserélve BUT 12-re) azonnal elszáll. A tranyót kiforrasztva, bekapcs. után a primer fesz. rendben (285V), és a készenléti táp is elindul. Köv. lépés: új BUT 12 be, bizti helyére 60W-os izzó. Az izzó közel telj. fénnyel világít,(a tv-re így csak kb. 60V eik) de a táp el kezd működni (természetesen a szekunder kőrben a névleges feszültségek töredékei, kb 40% mérhetők) Egyszerű eszközökkel mérve egyéb zárlatos, vagy szakadt alkatrészt -idáig- nem találtam, ja és a BUT 12 kollektor "hidegítő" 1,5nF cseréltem, de hiba továbbra is fenn áll. Előre is köszi.
Üdvözletem a Tanyának!
A fenti alaplappal szerelt, igen nagy méretű (82cm) 32PW8651/12
készüléket azzal a hibával hozták, hogy a pici gyermek a főkapcsolóval addig játszott (ki-be kapcsolgat), míg teljessé vált az üzemképtelensége. Készenléti LED nem világít, viszont a készenléti tápok megvannak. 5,2V, ill. 9V. Mérhető a 3,2V, és az 1,8V a digitális panelon.
ADOC (sajnos BGA) oszcillátora megy, SDA-SCL forgalom természetesen nincs. Már egy kolléga nézte a készüléket, és a digipanelt
okolta a hibáért, eddigi méréseim szerint is, az ADOC tűnik a hiba okozójának, segítséget kérek, mi kerülhette el a figyelmem?
Ötleteiteket figyelemmel várom, üdv:
exGelkás
A fenti tv-vel kapcsolatban lenne olyan problémám,hogy napról napra
több idő kellett a kép megjelenéséhez mígnem elérkezett az az idő mikor nem jelent meg a kép.
Próbálkoztam a kondik melegítésével de nem értem el semmi eredményt.
Egy idő után azt vettem észre,hogy a kép megjelenik de össze van csúszva a képcső közepén egy vízszintes csíkba.
Ezt orvosolta az eltérítő IC (TDA8172) cseréje. De így megint nem jelenik meg a kép.
A tápnál egy fesz kivételével minden rendben van. Ez a "P15" pontnál lévő feszültség készenléti állapotban 12,5V és bekapcsolva 13,5V-nak kellene lennie.
Míg nálam készenléti állapotban 4,15V, bekapcsolva 13,45V mérhető.
Tudnátok segíteni ,hogy mit lehetne kezdeni a tv-vel?
