PHILIPS CUCINA HR2792-FA CITRUS-PRESS
HOUSEHOLD - SERVICE MANUAL
120.7 KB
HOUSEHOLD
PHILIPS CUCINA HR2792-FA CITRUS-PRESS service manual (1st page)
Preview of PHILIPS CUCINA HR2792-FA CITRUS-PRESS [1st page]
PHILIPS CUCINA HR2792-FA CITRUS-PRESS service manual (2nd page)
Preview of PHILIPS CUCINA HR2792-FA CITRUS-PRESS [2nd page]
    PHILIPS CUCINA HR-2792FA HR2792FA HR 2792 FA HR2792 CITRUS PRESS HR2792-FA
Philips GC576/60/BC-NL 9206 AD-4 gozallomas zarlata-Hiba nem jelentkezett
A gozallomas a tulaj elmondasa szerint  " leveri a villanyt " Ehhez kerem a segitsegeteket amit elore is koszonok Udv
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips Cucina HR7765 szétszedéséhez segítség kellene. Megoldva!
Sziasztok! A fenti konyhai robotgépen a vágótengely kiszerelésének módját szeretném megtudni. Köszönettel: Nagy Á. Ne SM-et kérj. Azt különben sem itt kell! "Rajzot, service manualt, jobbra a "Keresem/WANTED" doboz "KATT IDE" gombján keresztül kérj!"
Philips Saeco HD8745 kávégép hibalámpa gyorsan villog. Megoldva.
Szép estét.
Szívesen odaadom ha valaki javít ilyet Budapesten vagy környékén.
