PHILIPS GX8510
TV - EPROM
Type: (BIN)
512.0byte
EPROM
    PHILIPS GX-8510 GX8510 GX 8510
40PFL4707 Philips logo and shutsdown
Dear Expert
The details of my TV is as follows
1. Philips 40PFL4707/F7 Manufactured March 2012
2. SMPS Board BA21P6F01 01 1
3. SMPS board has a sticker that says A21P6MPW C 7219720
4. This is a 110v Mains Supply TV sold in USA
5. I imported this from USA into my country where we have 230V.
6. I have a simple winding transformer that converts 230v to 110v
The TV has been having this problem.  Here are the steps
1. Mains power on
2. Front panel white led blinks 6 times
3. Philips logo display
4. TV shuts down immediately
5. Nothing happens.  If i press power button on TV or remote nothing happens
6. Have to power off and then wait for few minutes to experience same repetition.
Last two days, tried several times, only once the TV started and after 10 minutes it did auto shutdown as there was no input signal connected.
Does this indicate issues with SMPS or main cpu board ? Even if its faulty, how did it start once ?
More testing done as follows
1. Removed all connectors. Cleaned all three pcb with liquid cleaner. Cleaned all connectors externally and internally ( holes) using painting brush. Allowed everything to dry.
2. Reconnected
3. Started. This time, went past the Philips logo. I could connect a macbook via HDMI and play youtube videos on the TV for ~1 hours.
4. Using remote, entered service mode and initialized ( factory reset) the TV
5. For 1 hours of proper run, measured voltages. LED+24v was showing properly at 24v, AL+3.3v was at proper 3.3v and the P-ON-H1 was properly at 3.3v
6. After about 1 hrs, the screen shut down. The LED+24v is showing at 6v, AL+3.3v at 3.3v and P-ON-H1 is a 0v. This indicates the main cpu board has turned off the P-ON-H1 signal.
7. Power off, wait for 2 min. Power on... same philips logo and TV shuts down. Problem repeats.
8. Firmware is Code TVNB010_00_PF_XX91_BA PIC code U10_CM08:_40A_C7W_R_02. Did a google search and found no references if this firmware needs any upgrade.
requesting experts next steps to root cause the issue. I suspect the main board is bad and the SMPS is good. What if I manually put a wire from AL+3.3v to P-ON-H1 ? will the TV be on or is it risky for the main cpu board ?
I am attaching the service manual for this TV
Philips_28PT4401/00
Üdv Mindenkinek! Javítás alatt van a Philips_28PT4401_00 típusú készülék. BU2806 DF elszállt...Találtam rajzot a tanyán RAR formátumban, de kicsomagolás után .bin kiterjesztéssel jelenik meg. A .bin kiterjesztésre 1x azt olvastam, hogy át kell nevezni ISO-ra, majd a MagicISO-val láthatóvá válik. Hát nem! Segítség, tegyétek láthatóvá!!!! Köszönettel: FEJO
PHILIPS 29PT8344 MG2.1EAA nem indul, ciripel (sortranzisztor cserélve)
Van egy 29 inches PHILIPS 29PT8344 CRT Tv-m. Hibásan kaptam egy ismerőstől. (Vidd el vagy kuka jelmondattal) Nem kellett kétszer mondani. Szervizet még nem látott. A hiba, induláskor cirippel, kép semmi, hang semmi. Szóval táphiba. Kibontottam, első amit kimértem a sortranyó. BU2520DF. Hát a megérzésem jó. Elszállt. Vettem újat, beraktam. Sajnos továbbra is cirippel és nem indul. A neten kutakodva olvastam, hogy ez a TV szereti a sorkimenőt kivégezni :( . Ez nem esett jól. A tranzisztor indítási teszt után, még rendben van, szóval nem verte ki újból. Táp mosfet kimérve rendben van. Egy kis tanács, meg egy kapcsolási rajz jó lenne. Sajnos a panelon a feszültség szintek nincsenek megjelőlve. Minden segítséget előre is köszönök.
Philips 32PF9830/10 lcd tv nincs készenlét
A készenléti táp nem működik jó lenne tudni a pirosan jelölt alkatrészeket.
Köszönettel
