PHILIPS HD7810-15
COFFEE-MACHINE - SERVICE MANUAL
219.5 KB
COFFEE-MACHINE
PHILIPS HD7810-15 service manual (1st page)
Preview of PHILIPS HD7810-15 [1st page]
PHILIPS HD7810-15 service manual (2nd page)
Preview of PHILIPS HD7810-15 [2nd page]
    PHILIPS HD-781015 HD781015 HD 781015 HD7810 15 HD7810-15
Relevant COFFEE-MACHINE forum topics:
Philips HP5847 shaver stopped working
Hope I've selected the right forum, I don't speak Hungarian! I have a Philips shaver HP5847 in which I was replacing the rechargeable battery. Unfortunately while trying to fit it (with long tags attached) something must have shorted out while I was turning the shaver around and it suddenly stopped working (the motor had initially immediately started running as I inserted the pre-charged battery pack). I found the Service Manual on this site but unfortunately there are no component values shown on the schematic. It was helpful to see the circuit diagram and I noted a (small-value) resistor R20 in series with the motor (for load current-sensing). I found no conductivity through it, so I shorted that out and miraculously the motor started working! I checked out the data sheet for the SAA1500T charge controller but other than confirming my understanding of the function of the resistor gave no help in working out what kind of value I should replace it with... I guess it's a function of the actual motor parameters. I imagine it is going to be of the order of 1 Ohm or less but this type of surface mount resistor does not appear to have a value marking on it unlike the other components on the PCB. Can anyone suggest a value for R20 please?
Philips HI5916 gőzölős vasaló csipogó hangjelzést ad !
Sziasztok ! Már korábban szó volt a  vaslóról , sikerült vezérlő panelt beszerezni ! látszólag működik olyannyira  hogy állandóan  fűtene  minek következtében a hőbizti megadta  magát ! A készülékben  van még egy panel ami tápokat állít elő a procinak és 24 V ot a rellé meghúzásához ami a fütőszálat kapcsolja , nos ennek a panelnak a rajzát  keresem hogy tovább tudjak lépni   van egy pár SMD tranyó rajta vagy dióda talán rajz alapján lehetne eldönteni ! A hőfokszabályozó poti és termisztor ami a vezérlő panelhez csatlakozik rendben a hőbiti átkötve ideiglenesen a hiba behatárolása véget ! Várnám ötleteiteket ! Üdv!
Saeco/Philips Minuto kávégép javítás
Van nálam 2 db Philips Minuto kávémasina. A két lányomé. Én vettem nekik ajándékba pár éve, de nem egy megbízható masina.
Az egyik darálójával van gond. Megy a daráló motor, de nem darál. Hogy lehet szétszedni a darálót.
Az SM fent van a tanyán és próbálom értelmezni.
A másiknál elektronika hiba van. A vezérlés tápja az alaplapon van. 2A bizti stabilan kimegy rajta akkor is ha a panel az asztalon van már.
Gratez egyenirányító után puffer kondi van. FSQ0265R a kapcsolóeszköz. Gyanítom ez dobta fel a talpát. Aki javított ilyet az talált más elfáradt alkatrészt is a környékén?
FSDM0265RN és a nagyobb  FSDM0365RN van a HQ-ban. Vegyem a 265-öt?
Esetleg egy kapcsolási rajz valakinél?
Üdv Feri
Philips Senseo kávéfőző vezérlése /Megoldva/
Szevasztok! Vásároltam egy Philips Senseo kávépárnás kávéfőzőt. Egyetlen bajom van vele, hogy egyszemélyes kávét nem tudok vele csinálni. Túl sok vizet ad a 7 gr kávéhoz. Ezt szeretném megváltoztatni. Sikerült letöltenem a gép szevíz könyvét, de abban a vízszivattyúhoz csak egy "vezérlőegység" csatlakozik. Mielőtt szétszedném, érdeklődnék, foglalkozott e már valamelyikőtök hasonló géppel? Pontosabban az érdekelne, hogy milyen időkapcsoló van a vezérlőegységben? Egyszerű RC tag, vagy valamilyen PIC. Bár az utóbbi sem lenne gond, ha vissza lehet olvasni a tartalmát. Ebben kérném a segítségeteket, mert feleslegesen nem szeretném szétbontani. Üdv: Gyula
