PHILIPS PB52.1HU LC CHASSIS LCD TV SM
8.3 MB
PHILIPS PB52.1HU LC CHASSIS LCD TV SM service manual (1st page)
Preview of PHILIPS PB52.1HU LC CHASSIS LCD TV SM [1st page]
PHILIPS PB52.1HU LC CHASSIS LCD TV SM service manual (2nd page)
Preview of PHILIPS PB52.1HU LC CHASSIS LCD TV SM [2nd page]
    PHILIPS PB-52.-1HU LC CHASSIS LCD TV PB52.1HU PB 52 HU
Philips 40PFL7007K/12 does not power on - Chassis QFU1.1E LA
Hi everybody, I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board. What I have tried… Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate. And here comes what is not clear to me. 1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode? 2. Can I somehow check if the PSU is working? May be by activating some pin? 3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?.... What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms. The service manual is on this link: http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html Thanks Martin
Philips EM2E-AA alaplap,hangban 1 Hz-es kattogás.
Üdvözlet Mindenkinek! A készülék típusa:29PT9007/12,sasszi:EM2E-AA.A hang rendesen jön, de egy kb.1Hz-es elég hangos kattogással együtt.A kép kifogástalan,a készülék a hanghibától eltekintve rendesen működik.Kérném a segítségeteket,merre érdemes kutatni? irokéz
Philips TV vs. keresztlány
Sziasztok. Azt szeretném megkérdezni, hogy van egy Philips TV-m. Sajnos igen alacsony magasságban és a keresztlányom állandóan kapcsolgatta a ki/be kapcsoló gombját. Az egyik nap meg már nem reagált semmire, azaz nem vett fel áramot. Mi lehet ennek az oka? Válaszokat előre köszönöm. üdv.
Philips 39PFL 3008H/12 lcd tévé visszaáll készenlétre. (megoldva)
Sziasztok! Emlegetett készülék több sebből vérezve került hozzám. Tápegység zárlat (secunder oldali diódák) és ledsor javítást követően a következőt produkálja: Készenlétből indítva, felvillan a háttér, majd visszaáll készenlétre. Hátteret lehúzva rendben be lehet kapcsolni a tévét. Háttér viszont biztosan rendben van... és itt állt meg a tudományom. Van valakinek ötlete mit is nézek már el megint??? Köszönettel: Kiss Z. Tápegység: 17IPS20P
