PHILIPS TV MD-2.21E AA-2.22E AA-2.23E AA
7.3 MB
PHILIPS TV MD-2.21E AA-2.22E AA-2.23E AA service manual (1st page)
Preview of PHILIPS TV MD-2.21E AA-2.22E AA-2.23E AA [1st page]
PHILIPS TV MD-2.21E AA-2.22E AA-2.23E AA service manual (2nd page)
Preview of PHILIPS TV MD-2.21E AA-2.22E AA-2.23E AA [2nd page]
    PHILIPS TV MD-2.-21E AA-2.-22E AA-2.-23E AA MD2.21E AA2.22E AA2.23E MD 21 22 23 2.21E 2.22E 2.23E MD-2.21E AA-2.22E AA-2.23E
Philips 40PFL7007K/12 does not power on - Chassis QFU1.1E LA
Hi everybody, I have Philips 40PFL7007K/12 on repair. TV does not start up. I have checked the PSU and it seams to be OK. There seam to be problem on the main board. What I have tried… Well, there is +3V3-STANDBY coming from PSU to main board. This feeds up the main processor. This voltage has also been used to switch TV on. I have checked that switching signal from POWER ON button goes back to main board. But I did not check this whole path towards the processor as it is BGA package and it is covered by ceramic cooling plate. And here comes what is not clear to me. 1. How to check if the main processor works? Does it work on the +3V3-STANDBY when TV is is standby mode? 2. Can I somehow check if the PSU is working? May be by activating some pin? 3. I have noticed by measuring (ohm-meter) some capacitors on the main board (in circles on the picture) that there is very low resistance on them (4.5ohms). In the scheme it is shown that these capacitors are on the 1V5 (1.5V) line. Is this OK? Basically it does not give much current as I = 1V5 / 4R5 = 333mAmps. What do you think? Certainly there are low voltage data parts (RAM. Processor …) connected and such resistivity might be correct….?.... What I have also find that this 1V5 is split into 1V5M0 and 1V5M1. See the picture. I have removed the coils and measured resistance. Then 1V5M0 shows about 15ohms and 1V5M1 shows about 6,5ohms. The service manual is on this link: http://elektrotanya.com/philips_ch.qfu1.1e_la.pdf/download.html Thanks Martin
Philips 40PFL3078K/12-TPM10.1E LA, komplett háttér csere után sem világít a háttér, hang van!
Ma cseréltem a komplett hátteret, de bekapcsolás után sem világít a háttér. A led meghajtójaSSL400_0D5A nem ad ki se milyen feszültséget a ledek felé, 24V meg van, biztosíték jó, a többi feszt is megkapja. Teszek fel képet róla hátha valakinek volt-e már ilyennel gondja?
Philips fl 1.17
Sziasztok,mindenkinek! Lassan haladok ezzel a tv hibafeltárásával,indulásból 2-3mp után visszaáll készenlétbe.A 140volt is csak 120 volt,a lehetséges szokásos 150nf,33mikró,stb megvizsgálva,cserélve,a sorkimenő kivételével sem jelenik meg a 140 volt,a sorvég 2db bu508 jó!Kérem,ha valaki behatóan taulmányozta eme technika lelki világát,néhány instrukcióval segítse a javításomat,köszönöm előre is.Itt kérek elnézést,mivel sajnos az előző témához küldtem be először a kérdésemet.Köszönöm előre is a segítő hozzászólásokat,további szép napot mindenkinek!
PHILIPS 25pv808/39
Sziasztok! A címben említett típusban meghalt a ptc vgy ntc ptk nem tudom 3 lába van epc05 t209 ü102 felirattal a tetején ez van a dmag körben. Pontossan mi lehet ennek a típusa mit rakjak bel? Most nélküle megy a tv-m csak attól félek foltos lesz a képernyő ha van sematic jól jönne. Vagy elég a típus. Segítségeteket előre is köszönöm.
