PIONEER DV-535 RRV2388 DVD PLAYER SUPPLEMENT
VIDEO-DVD - SERVICE MANUAL
16.5 KB
PIONEER DV-535 RRV2388 DVD PLAYER SUPPLEMENT service manual (1st page)
Preview of PIONEER DV-535 RRV2388 DVD PLAYER SUPPLEMENT [1st page]
PIONEER DV-535 RRV2388 DVD PLAYER SUPPLEMENT service manual (2nd page)
Preview of PIONEER DV-535 RRV2388 DVD PLAYER SUPPLEMENT [2nd page]
    PIONEER DV-535 PLAYER DV535 RRV2388 DVD DV 535 RRV 2388
LG LV2578 RF kimenet norma váltás
Sziasztok! A fenti készülék rf modulátorának a norma váltásában kérném a segítségeteket, most DK hangja van és BG kellene. Köszönettel : Laci
Daewoo video
Sziasztok. Daewoo ST 867 video magyar nyelvű felhasználói könyvet keresek.Előre is köszönöm. Solyom
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
TV Modulátor Philips videóban fekete fehér kép
Van egy Philips videóm, amit arra használok, hogy a ház antenna rendszerére rányomjak UHF jelet. Van egy lepke antenna (erősítővel a tetőn kívül). Ennek a jele bemegy Stong digit műholdvevőbe majd a VHS Philips Video koax bemenetére innen megy ki a modulált jel egy Hirschmann ant erősítőre. Utána rámegy egy 8-as splitterre (üresek lezárva)(4 tv-t hajt), és innen megy ki a fali aljzatokra és a tv-k re. A videó frekvenciáján a kép csak fekete-fehér az antennáról jövő adók pedig mind tükör simák mindenhol. A digit műholdvevő képe pedig szép, de enyhén hangyás. Ha kihúzom a lepkét a digit műholdvevő uhf frekvenciáján kisimul a kép és a vhs Videó frekvenciáján be be ugrik a szín. (a videó önmagában tv-re dugva színes képet szolgáltat) Hol lehet a hiba, és mi lehet a megoldás? Esetleg túl erős a bemeneti jel a lepkéről és a zaj rá szuperponálodik a modulátor frekvenciákra? Vagy a bemeneti jelek túlvezérlik a modulátorokat? hogy lehet, hogy az antenna képe, mindenhol megfelelő erősségű és tiszta képet ad, de a Modulátorokról lejövő jelek egyik sem tiszta? Sőt a videó képe sötét fekete fehér(hang az rendben). Erősíteni, vagy csillapítani kell a jeleket? Vagy valami illesztési hiba? (műholdvevő és a videó között nincsen kicsatolás, csak egy sima koax van. Tanácsokat segítséget köszi Szautner Béla :help:
