POWER SUPPLY REPAIR KITT FOR CHASSIS TX 807 CCS 110 TX807C CS
If you have any question about repairing write your question to the Message board. For this no need registration.
If the site has helped you and you also want to help others, please Upload a manual, circuit diagram or eeprom that is not yet available on the site. Have a nice Day!
Warning! If you are not familiar with electronics, do not attempt to repair! You could suffer a fatal electrical shock! Instead, contact your nearest service center!
Note! To open downloaded files you need acrobat reader or similar pdf reader program. In addition,
some files are archived, so you need WinZip or WinRar to open that files. Also some files are djvu so you need djvu viewer to open them.
when i turn on the tv from standby i can access from control panel or remote control but after its red umber light blinks three times nothing comes/no video no audio / and to turn off i can access only from remote control i can't access from control panel.
please tell me what i am going to do
thank you so much
have a toshiba TV 32EL933G , the Power LED turns green but the TV does not give anything . the power supply in the secondary has no tensions , is not to boot. power supply is PE-3850-01UN-LF does not swing to start the secondary :(
Hi everybody, my first post here.
I've found on this site many information and the service manual about the TV in subject, but I stumbled upon a strange issue.
I repaired the earphone socket (pic attached) that had been stripped away and now the TV doesn't power on, it only gives a short beep when you touch the power on button and nothing happens using the remote. I checked the usual things (audio paths, cracked solderings, damaged tracks, power supply, power rails), but I cannot found what's wrong.
Any idea/clue on what to (double) check this time?
Hellosztok segitségeteket szeretném kérni a fent emlitett tv-vel kapcsolatba.A tv sasszi száma 11ak28-6. A készenléti led villog a táp kattog és nem indul.azért kérném a segitségeteket hol kezdjem a javitást:annyit tudok hogy a 135v-os résznél 150v van de folyamatosan ugrál 137 és 151 között.A secunder oldalon kicseréltem a kondikat de a hiba még fenn áll a trimmerrel nem tudom állitani a 135v-ot.Várom válaszaitokat üdvözlettel saca
If you want to join us and get repairing help please sign in or sign up by completing a simple electrical test or write your question to the Message board without registration. You can write in English language into the forum (not only in Hungarian)!
