PROLOGY HDTV-705XS HDTV-805XS SCH
CAR-AUDIO - SERVICE MANUAL
620.1 KB
CAR-AUDIO
Looking for similar prology manual?
    PROLOGY HDTV-705XS HDTV-805XS HDTV705XS HDTV805XS HDTV 705 XS 805 705XS 805XS
Becker Cascade BE7944 need help!
Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
 I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
RNS 510 navigáció térkép és magyarosítás
Egy Skoda RNS 510/Columbus autó navigáción szeretném a jelenlegi térképet megfrissíteni! Ha jól tudom a V17(8557) a legutolsó verzió erre a készülékre.
Jelenlegi verzió:
  • 3T0035680K
  • HW-Version  H70
  • SW-Version  5238
  • West Europe
  • Navteq
  • Map Version HDD  8536
Tudna valaki ajánlani megbízható letöltési helyet, frissebb Európa térképhez?
A készülék magyarosítására(menü+beszéd) van lehetőség vagy csak a fizetős út járható?
Köszönöm előre is, ha valaki bármilyen infóval tud segíteni!
Üdv. Miki
Fiat Stilo Visteon OA autorádio nem müködik
Sziasztok! Vásároltam a lomis piacon ma egy fiat stilo gyári autorádiot. De nem birom müködésre birni.fotot csatoltam,netes de ugyanaz a jelenség. Kérdésem,lehet-e valahogy müködésre birni,hogyan?(ECU nélkül) Válaszokat elöre is köszönöm! Üdv:Atis
Alkatrész beazonosításban kérnék segítséget - MEGOLDVA
Ötleteket kérnék, hogy mi lehet a következő alkatrész egy autórádióban:
+5V a bemeneti feszültség
Kimeneti feszültség ismeretlen, de talán 3V3
A feliratból annyi maradt hogy:   AM
Tokozás:  SOT-89
A középső láb (forr fül) a kimenet !
A jobb oldali láb van +5V tápfeszen a bal oldali testen, a középső láb a kimenet.
Egy memória mellett van, ezért tippelek a 3V3 -ra !
Köszönöm  !
István
Megoldva: AMS1117
