RCF ART200A SCH
443.1 KB
Looking for similar rcf manual?
    RCF ART-200A ART200A ART 200
RCF aktív hangfalban ismeretlen IC
Szép napot Tisztelt Kollégák! Egy RCF gyártmányú, ART708-A típusú (Digipro600) aktív láda erősítőjében lévő SMD IC-ről nem találok semmiféle dokumentációt, leírást. Ami az IC-n szerepel: AEB DPI 829P. Esetleg tudna valaki segíteni ennek az alkatrésznek a beazonosításában? Üdv: István
RCF art 415-A speaker - PSU not working
Hello everyone,
I've this speaker model:
RCF art 415-A.
The power supply is faulty, no votltage out to the amplifier.
The Mosfets are blown. I've changed the mosfets and it's driver, and still have a problem.
I tried to switch on but only one of the mosfets gets hot (the one which switches the 310. There are 2 of them - Mos5 in the scheme).
Obviously I turned it off.
1) What causes it to heat?
2) Testing the VCC of the LMC555, it's only 2.7V. When taking it out of the circuit, it's 12VDC! What makes the voltage to drop. Where does the supply of the LMC555 come from? The VCC of the 555 should be around 10V, as compared with a good card.
I've changed the 555, but the problem remained. I've checked the components around, resistors and capacitors, and transistors, and seem to be OK.
4) The VCC of the Mosfet driver is 10V, but should be 12V if compared with a good card.
3) Could the trafo be damaged? Are these parts reliable or may blow up?
4) What is the purpose of the optocoupler in the circuit?
I would really appreciate any help.
I didn't find the 100% schemes for this RCF (400), but found a very similar one (The 600 version).
name and a link here to download the pdf.
DigiPRO600B
https://elektrotanya.com/db-technologies_digipro600b_sch.pdf/download.html
Regards and many thanks
RCF Aktiv hangfal
Sziasztok Egy RCF TT08A aktiv hangfalat szervizelek, az erositoreszben megment valami, tele van smd elenallasokkal es par ossze van egve. Valakinek ha van szerviz konyve vagy hasonlo hangfal amirol tudna infot adni, megkoszonnem. Udvozlettel, Szabi
rcf art 710-a mk4 gerjedve indul, pukkanással áll le
RCF ART710A mk4 hangfalat javítanék, a panel valószínű nem eredeti, azaz nem az ART710A ba való, a magassugárzó D-Class SMD FET es nem a hűtőtönkre csavarozott. DP600 van a panelre írva, eredeti RCF de valamelyik másik kétutas PA ból származik, teljesen illeszkedik az alu öntvényre.
Bekapcsoláskor sipolva, gerjedve indul, így:
https://www.youtube.com/shorts/KhvBDVSqCps
Kikapcsoláskor pár másodpercel a táp elvétele után pukkan. Olyan mintha nem lenne elég ideig MUTE ban. A tápja mechanikusan is sipolva-nyekeregve indul, ha ilyenkor a mute elmúlik és még sipol a táp akkor azt hallani a hangszórókból. AEB DPI IC hajtja a két két végfetet a két D-Clas ban az 5ös lábon nincs időalap kondi, az 5 ös láb a levegőben lóg. De mégis később indul a 415kHz körüli négyszögelés, csak nem tudom hogyan oldották meg. Ezt az időt kellene meghosszabbítani, gyári RCF kommunikációs kábelem, programom nincs, pedig az XLR en keresztül is lehetne flash elni van egy kapcsoló erre az egyik XLR csavar alatt, amivel át lehet kapcsolni service modba.
A kérdés azokhoz akik ismerik az RCF ek lelkivilágát, a mute időt itt lehet programozni, vagy van egy kondi vagy ellenállás valahol ami időalap?
Esetleg más ötletek?
