REPAIR GUIDE2 TO PHILIPS PLASMA SUPPLIES 3104-328-42741 OR 3104-328-42742 SM
TV - INFO-TIPS
825.7 KB
INFO-TIPS
Looking for similar repair manual?
REPAIR GUIDE2 TO PHILIPS PLASMA SUPPLIES 3104-328-42741 OR 3104-328-42742 SM service manual (1st page)
Preview of REPAIR GUIDE2 TO PHILIPS PLASMA SUPPLIES 3104-328-42741 OR 3104-328-42742 SM [1st page]
REPAIR GUIDE2 TO PHILIPS PLASMA SUPPLIES 3104-328-42741 OR 3104-328-42742 SM service manual (2nd page)
Preview of REPAIR GUIDE2 TO PHILIPS PLASMA SUPPLIES 3104-328-42741 OR 3104-328-42742 SM [2nd page]
    REPAIR GUIDE-2 PHILIPS PLASMA SUPPLIES GUIDE2 TO OR GUIDE 3104 328 42741 42742
repair LG 47LD450 power supply problem
I have LCD LG 47LD450 model . The problem is the power supply - EAX61289601 / 11. No full esqema this power supply , already identified several burned Components that can not know the reference. Someone can help me? Components list burned: R230 R218 Q201 IC0201 R217 D605 R615 R617 R621 Q602 Q601 Best regards Nuno
LG 42LD420 42LD428 LD01B LCD TV Service Repair Manual
Sziasztok! Valaki tud ehhez a TV-hez service manualt? Vagy honnan lehetne letölteni? Köszi! Attila
PS42C7HD repair tip - diagnosing maldischarge/poor picture
MODEL: PS42C7HD FAULT: The plasma display shows no picture or the picture has significant maldischarge. Maldischarge includes unlit patches of display, overly bright parts, sparkling/unstable pixels or unlit pixels on colour bands. DIAGNOSIS: Requires an oscilloscope. Should check Y-main waveform (was only about 20Vp-p when I checked it, should be >400Vp-p) FIX: Replace 100uF 50V cap near yellow trafo on Y-main board --Also encountered this fault with same model-- MODEL: PS42C7HD FAULT: Clicking relay, no picture or sound DIAGNOSIS: Identify shorted sustain board (X-main or Y-main.) Unplug either board in succession and see if set stops clicking FIX: Repair or replace the X or Y-main board. --And this one, too!-- MODEL: PS42C7HD FAULT: Maldischarge but the 100uF cap is OK. DIAGNOSIS: N/A FIX: Adjust Yrr/Yfr controls. Drop Vs by about 5V.
