Sziasztok. A minap megtoltottem a cimben szereplo mf. gepnek a tonerjet, de 2 csippel is azt az uzenetet adja, hogy "nem kompatibilis toner". A gep uj, 450 oldalt nyomtattak vele, ez lenne az elso toltese a tonernek. Talalkozott mar valaki ilyen jelenseggel? Udv.
ADMINISTRATOR: Please move this to the appropriate forum. The forum titles are in Magyar and I cannot understand them.
The Samsung CLP-310/315 and CLX-3175/3178 are great color laser printers and can be had quite inexpensively. But a set of replacement cartridges can cost more than the printer.
Refill toner is very inexpensive--I use Meritline.com but there are other sources--but the cartridges contain an I2C EEPROM which records page count. You can refill the cartridge but it will still be reported as exhausted.
A quirk of the printer design is that the original cartridges that come with the printer have no EEPROMS; their counts are stored in system EEPROM. With a simple modification to the printer you can erase these counts and cause the printer to accept any cartridges for multiple reuses.
This is documented at http://rumburg.org/printerhack/ . I've done this to two printers and it has worked well for me.
Larry M
Sziasztok. Van egy, a cimben megnevezett multifunkcios nyomtatom. A feketet csikokban vitte fel, ezert a hengeregyseget szet kellett szedjem, es kitakaritsam a fekete developer egyseget. Mivel a papiron 2 halvany szines csik is jelentkezett, kivettem a transfer folia egyseget is, es elforgattam. Osszerakas utan "transfer belt error" hibaval kiall, es barmilyen pozicioba forgatom el a transfer foliat, a hiba marad. Bekapcsolaskor nem azonnal dobja ki a hibauzenetet, hanem vegez egy ontesztet es utana. Tudja valaki a megoldast erre?
Sziasztok. Behoztak 2 drb Samsung ML1610 tipusu nyomtatot javitani. Mindketto ugyanazt a hibat produkalja - bekapcsolas utan beall a keszenleti allapotba, es ha nyomtatast inditok rajta, rogton a lap felvetele utan leall es 4mp idokozzel mindket led kigyul illetve elalszik. Jart mar nehany ilyen es hasonlo nyomtato a kezem kozott, de ezzel a hibaval most allok szembe eloszor, raadasul ez a lassu villogas szamomra ertelmezhetetlen, mert a szerviz konyvben valami kutyurol irnak, amit csatlakoztatni kell a nyomtatohoz, es kiir egy 2 szamjegyu kodot, aminek a megfejtese persze mar megvan. A formatter panel mukodik, ha csatlakoztatom a PC-re, az felismeri. ha kikapcsolom a nyomtatot, a PC vonyit egyet, ha bekapcs, ugyszinten. En a lezer egysegre gyanakszom - ebben kernek megerositest/cafolast- ha valaki talalkozott ezzel a hibaval.
