Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
sziasztok: megnézném az alaplap forrasztásait, de nem tudom kiszedni.
Az előlapot kiszedtem, de a gyanús a Kép43A ábrán, a hűtőbordán látható 4 db 5mm-es lyuk, olyan, mintha csőszegecs lenne.
Antenna és csatlakozója jó, amikor elhallgatnak a hangszórók, a kijelző világít, mutat.
A gyereké, egy 11 éves OPEL Astra G-ben van
Szedett szét ilyet valaki, vagy csak erőszakosabban kell bánni vele?
VW Tiguannál hogyan lehet kitörölni az olajcsere intervallumot?
Köszi.
Sziasztok, a tulajdonos állítása szerint az este leállított autóban a rádiót reggelre véletlenszerűen bekapcsolva találják. Ha jól néztem, ezen nincs gyújtás pont, csak direkt B+. Tényleg be lehet kapcsolni kivett kulccsal is, de ilyenkor adott idő után kikapcsol. Sőt a rajza szerint feszültségcsökkenésre is lekapcsol. Találkozott már valaki ilyesmivel? Előlapi gomb okozhatja?
Minden segítséget köszönök!
Laci
Vadmalacka javaslata alapján szétszedtem a CD loader kapcsolót, megtisztítottam, leápoltam az érintkezősávokat, összeraktam. A gép több mint 2 napja készenlétben van, egyszer sem kapcsolt be. Nagyon köszönöm a segítséget, a téma lezárható.
Még egyszer köszönöm!
Laci
