SCOTT 209 INTEGRATED AMPLIFIER SCH
Type: (JPG)
285.1 KB
Looking for similar scott manual?
    SCOTT AMPLIFIER 209 INTEGRATED
Audio erősitő
KENWOOD KA-3300 erősitő kapcsolási rajza. Elöre is köszönöm ha valaki elküldené. pennge@vipmail.hu
May be useful - Harman Kardon information
For your information to repair Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown) can be changed without any other servicing Harman Kardon Receivers; Series AVR 2000,3000... "Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time. "Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V. "Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there. "volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V! "everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function. Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts. So i hope i can help you... cheers SG.
Revox B77 javítása - Jobb csatorna felvételi hiba
Tisztelt Kollégák és Fórumtársak!
A hétvégén gondoltam egyet, nosztalgiázni volt kedvem ilyenkor előveszem gyűjteményem egy egy darabját aztán játszadozom vele egy kicsit. Most magnózni lett kedvem, mi tagadás engem lenyűgöznek ezek a masinák; az orsók forgása és ahogy a szalag susog a mechanikával - szeretem nézni és hallgatni....
Mi tagadás, rittkán kapcsolom be készülékeimet, inkább a polcon pihennek és néha letörölgetem a port róluk... Mint ahogy hallottam nem tesz nekik jót ha sokat állnak, de tetszik vagy nem tetszik időm a hobbymra sajnos erősen korlátozott. Aztán a szerveren otthon annyi zene van amit valószínüleg a hátralévő életemben - sose tudok végig hallgatni.
Most hétvégén azonban volt egy kis időm játszadozni és befűztem találomra egy szalagot, gondoltam készítek felvételt is vele. Itt kezdődtek a problémák. Az volt a jelenség, hogy a felvételre kapcsolva a készüléket látszólag minden rendben volt, a műszerek jelezték a felvétel szintjét, lámpák rendben világítottak, látszólag minden oké... Majd eltelt úgy 15 perc és azt vettem észre, hogy a jobb csatornán a jel szintje egyre csökken aztán a VU méter mutatója meg se mozdul míg a bal oldal működött megfelően.
A készüléken - mint tudjuk 3 fejes - lehetséges ellenőrizni a felvétel közben azonnal, mi a helyzet a szalagon. A monitor kapcsolót átkapcsolva LINE módba szólt rendben minden, de vissza kapcsolva Tape módba csak a bal csatorna szólt.... :-(
A törlés működik a régi felvételt letörölte. A lejátszás is jó, más szalaggal is próbáltam és a felvételeket megfelelően szólaltatja meg.
Kérdésem volna hozzátok hol érdemes elkezdeni a hibakeresést? Minden ötletet szívesen fogadok. Annyit tudni kell még, hogy készüléket kb. másfél éve szétszedtem és minden csatlakozót, potenciómétert, üzemmódkapcsolót kitisztítottam és ahol szükséges volt cseréltem.
A szervízkönyvet már le is töltöttem, de egy gyakorlatias tanács sokat segíthet amit előre is köszönök!
Philips Fw-c355/34 végfok csere
Hozzám került a fenti készülék  a tulaj bevallása szerint  széthajtották. Maxin  ment aztán elhallgatott.Néztem a kapcsolási rajzot ahol a végfok  tápja 16,2V nálam mérve 36,2V. A FET átvezet. Renben  , rendeltem hozzá egy teljes végfok áramkört. FET , IC két tranyó a védelemhez. Beépítettem a két tranzisztort és a FET-et de az IC 1. lábára (nincs beültetve)  megint csak 36,2 volt jut. Diódákat mértem jók .Mivel elég nehézkes és drága az alkatrészek beszerzése nem akarom megkockáztatni hogy beültetem az IC-t bár az a gyanúm hogy csak akkor áll be üzemi feszültségre. Ebben kérném a segítségeteket.
Üdv Belfi!
