SIEMENS WHV4280 SCH
344.1 KB
WASHING-MACHINE
    SIEMENS WHV-4280 WHV4280 WHV 4280
Siemens IQ700 mosógép F67 hibakód (megoldva)
Sziasztok. Siemens IQ700 mosógép F67 hibakódot ír. Utána olvasva valami komunikációs hibára utal. Emlékeim szerint volt valami teszt mód belépés. Azt tudja valaki? Vagy van valami ötletetek a hibára? Köszi elore is. Üdv. G. Megoldás: Nagy Köszönet "Tivi"-nek. https://www.youtube.com/watch?v=kBSD5rkTLcU
Siemens KG49EAI30/10 hűtő táp ic eldurrant.
Sziasztok! A címben szereplő hűtő elektronikáján lévő táp ic tipusát keresem,sajnos eldurrant és nincs meg a kalapja nem tudom a típusát a google pedig nem segített.
Előre is köszönöm!
Dryer Siemens Series:iQ500, type: WT45W468GR -Error code E-56
Good evening.
 I have a Dryer machine model: Siemens iQ500 and frequently appears the error code E-56. After switcing off the dryer and switch on again the dryer works fine. Does anyone know what this error code means? Sometimes also when I touch the start button the beeper sounds two times and I have to turn off the main switch and turn it on again as well as to reopen the door of   the dryer and close it again so as to work the dryer. I have already replaced the magnetic switch of the door.
Thank you in advance.
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
SIEMENS 300054-033755 programkapcsolót keresek!
Sziasztok!SIEMENS mosógépbe keresek 300054-033755 programkapcsolót!Bontott érdekel.Új is szóba jöhet.Cseréről is szó lehet.Van u.i. szintén SIEMENS 03610980-1599 301222-009924 számú programkapcsolóm.De ez az utóbbi nem jó bele.A mosógép típusát késöbb megadom.A kijárószerelő majd fölírja az adattábla tartalmát.Utána fölteszem ide.Segítségeteket előre is köszönöm.Üdv Jano
