SONY D-11 D11 SCH
4.6 MB
SONY D-11 D11 SCH service manual (1st page)
Preview of SONY D-11 D11 SCH [1st page]
SONY D-11 D11 SCH service manual (2nd page)
Preview of SONY D-11 D11 SCH [2nd page]
    SONY D-11 D11 11
sony potentiometer 2x50KA alphs
Hi,
Mine sony amplifier TA-F444ES needs a (alphs) balance potentiometer pn 1-228-905-00 res,var,carbon 50k/50k with center detent.
Anyone who knows a reliable source ? shaft 6mm length shaft 2cm diameter potmeter 16mm
SONY CMT-S20B mini hifi kijelzője gyengén világit :
Sziasztok ! A fenti hibán hogyan lehetne segíteni zöld színű fűtőszálas kijelző van benne pontosan nem tudom megnevezni a típusát. a fűtő fesz 24volt helyett csak 23 volt ez lehet a gond? Üdv nektek!
SONY HCD-H51 hiba
Hali mindenkinek. 2 kérdésem volna. A fenti hifit javítom, és az a gondja, hogy a lézerfejet le-fől rángatja (fokusz tekercs). Ez kb. 1 perc után megszünik. Ekkor a lemezt is megforgatja, beolvassa a track-eket, de a lejátszás nem megy. A KSS240-es pick-up-on melyik a lézeráramot állító poti, mert nincs kedvem kibontani. Ezen 3 van a szokásos 1 helyett, 1más mellett Előre is köszi Attila
repair sony amplifier str-de254
Want to share: Have downloaded the schematics from this forum to help repair the amplifier of a friend. Turned out that Sony decided to route the earth through the chassis, even the earth between the various supplies. When one takes the main board out of the chassis and switches the amp on, there are up to 20 volts difference between the eart (and hence reference) of the pre-amps and the main amps. Luckily the amp goes into protection but from a design point of view it is not nice to rely on screws and aluminum face plates to conduct up to 0.2 amps of current from one supply to another. What I did is solder wires to every eart point and connected them on the main board to make it stand alone and not rely on conducting current through the chassis anymore. Bad design, simple repair but took some digging in the schematics to find out what exactly was going on!
