Hello,
Here is video at the moment that the part can be seen: https://youtu.be/PjEBGFLjgM0?t=410 (from about 6:50 mins). At 10:44 is seen that the part is only in the bottom side of the slot; and nothing more detailed in the whole internet that I was able to check for about a hour.
There is magnetic field sensor - top left on the DSC07181 and on the next photo fitted on its place, so I think it should be some kind of tiny end position switch or don't know what;
Regards,
Milen
Hi everyone,
Could somebody tell me how I can get (or buy) the Sony AdjustStation with the adjustment manual for my old Sony A55V camera? Recently, the IBIS died in this camera, and after some time the shutter died too. This rendered the camera completely unusable. Since the camera is quite old, no repair shop near me was willing to fix it at a reasonable price. So I bought the shutter unit and IBIS on AliExpress and successfully swapped them. The problem now is that the shutter is clearly misaligned. The service manual says that after replacing the shutter and IBIS, they must be calibrated to work properly. According to the manual, AdjustStation software is required for that. The camera is very important to me as it holds many memories, so I’m determined to get it working again.
Szervusztok!
Van a fent nevezet kamera,a hiba jelenség.Akkuról indítom a kamerát akkor 1 másodperc múlva ki írja,hogy kéri a DC csatlakoztatót csatlakoztatni és és tölteni. "(USE NEW AC ADAPTER OR REINSERT)" Az érdekesség hogy új akkuval is ezt csinálja de ha hálozatról működtetem akkor minden rendbe van rendesen működik a kamera.Ha ebben tudnátok segíteni azt meg köszönném.
Üdvözlettel: buszosgyuri!
UI. Az akkuk fel vannak töltve!
:help:
Kedves Kollégák!
Nincs véletlenül bontásból egy jó 2,4"-os LCD panel Sony DCS S930 fényképezőgépbe? Az S700, S730, és Olympus FE-25-nek is ugyan ez a kijelzője. Ha valakinek viszont kellene, nekem van bontásra egy Pentax Optio 50-es táphibás, de sérülésmentes mindene. Köszi, Sanya.
