SONY HCD-DZ265 266 270 570 777K
VIDEO-DVD - SERVICE MANUAL
4.6 MB
SONY HCD-DZ265 266 270 570 777K service manual (1st page)
Preview of SONY HCD-DZ265 266 270 570 777K [1st page]
SONY HCD-DZ265 266 270 570 777K service manual (2nd page)
Preview of SONY HCD-DZ265 266 270 570 777K [2nd page]
    SONY HCDDZ-265 HCDDZ265 266 270 570 777K HCDDZ 265 777 HCD DZ265 HCD-DZ265
SONY VCR
SZiasztok Van egy Sony SLV363EE videóm.A capstan motorja 2-3mp-ként megáll egy pillanatra.A hozzászólásokat előre is köszönöm.
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Sony EV-S9000 Hi8 as videomagnó kezelőpultnak nincsen kijelzése megoldva !
Sziasztok Kaptam egy SONY EV-S9000 tipusu Hi8 as videómagnót a következő probléma vele a motorosan kinyiló kezelőpultban van egy kijelzőegység ami nem működi a többi gomb tökéletesen működik csak kijelzés nincsen ha esetleg valaki tudna segiteni vagy rajz róla ha lenne valahol a neten nem találtam róla semmit.
Sony SLV-X9N videó eject utasításra kiadja a kazettát, de rögtön vissza is tölti.
Sony SLV-X9N videó eject utasításra kiadja a kazettát, de azonnal vissza is tölti. A mode-switch kitakarítva, a panelon lévő mikrokapcsoló megjavítva. A  sasszin lévő fogaslécen egy kis műanyag lapka le volt törve, azt visszaépítettem, remélem jól. Persze, ha elég gyors vagyok, ki tudom venni a kazettát, de akkor is visszaindul a kazetta fészek, de természetesen elakad a reteszelő lemez (remélem, ez a neve) miatt. Tudna valaki tanácsot adni, hogy hogyan tovább?
Köszönettel:
