I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Hi all !
I plug the plug into the socket. The blue standby LED lights up. I press the standby button. But the amplifier does not turn on, the LCD display does not light up. When you press the standby button again from the 15th to the 20th time, sometimes it is possible to turn on the amplifier. Previously, a similar thing happened after a long period of inactivity of the amplifier unplugged from the outlet. But after turning it on to the outlet and warming up in standby mode, everything seemed to return to normal, and the amplifier was turned on with the standby button the first time.
And now, after standing for 3-4 weeks (unplugged from the outlet), only from the 15th or 20th time.
Thanks.
Sziasztok Kedves kollégák!
A fenti erősítőhöz keresnék kapcsolási rajzot, a fégfokba szét égett egy két alkatrész, és ezeket kellene beazonosítani.
Köszönöm előre is!!
Csaba
Hali!
Kicseréltem a mikrokapcsolókat ,de semmi vátozás!
Bekapcs, tuner 2x villan majd kiirja eject!
Táp mindenhol jó!
Még mindig nem tudom mi lehet a baja ?
Talán procihiba?
SEGÍTSETEK!!!!
Üdv Korz
