There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
Tudnátok segíteni? Lenne ez a gép. Megy kb. 5-10 percet és totál leáll
a tápja a TNY ilyenkor kellemesen meleg. Hül egy kicsit,
visszakapcsolható.
Amit eddig csináltam:
Átforrasztottam a primert.
Leellenőriztem az elkokat, a primeben és a secben.
Cseréltem a TL431-et, de ugyanaz:(
Mi lehet, TNY??
Köszi
Szevasztok
Van ez a fentebb leirt hütőpult,amit sajnos nem én szedtem szét,de céges melóként a nyakamba varták,na ennek van egy transzformátora ami toroidra van tekerve,na ez lángolt,ez a trafó melegiti az üvegre felvitt szálakat,és ez jégtelenit,nemtudom hátha találkozott valamelyikőtok ezzel a pulttal,és tudna segiteni a trafó adataival.
A primer 220,a szekunder nemtudom,duplán volt tekerve olyan 1,5 drótból.
Igy néz ki a hütő,hátha igy jobban felismeri valaki.
Üdvözlök mindenkit itt a tanyán!
Szert tettem a fenti címben szereplő időjárásjelző készülékre, de sajnos eléggé gyérek az ismereteim a tovább lépéshez.
A készülék hibásan került hozzám, egy szélsebesség és szélirány mérő, és egy hőmérséklet mérővel ami már hibátlanul működik,
most már mind a 8 bemenet működik rajta. Szeretnék hozzá még egy csapadék mennyiség és páratartalom mérőt is, de sajnos nem tudom hogy miként keressek hozzá valót természetesen emberi áron. Remélem itt a tanyalakók közül találkozott már valaki efféle eszközzel és tud segíteni a beszerzésben.
A lufft honlapján már próbáltam szétnézni de sajnos azon kívül hogy kifutott széria semmi számomra értelmezhetőt nem találtam, így se kezelési leírás, se műszaki dokumentációm nincs a készülékről. Ezért tehát igen problémás számomra egy efféle külső periféria kiválasztása az internetről.
Ha tud valaki segíteni azt előre is köszönöm.
Krisztián
