Hello everybody!
I have at the moment a electronic module of a washing machine, and i can´t identify some SMD components to replace.
As you can see on the attach file, there is a SMD with the code 6A. i can´t find this, and i don´t have the electronic schematic.
If anyone can help, i apreciate.
Thank you very much.
Nelson Ferreira
TEKA GKST 60 I4 főzőlap nem kapcsolható be,mert a tápegység IC zárlatos.
Abban kérem a segítségetek,hogy a panelen lévő ICE3B0565 tápegység IC 3-as
lábára milyen értékű ellenállás csatlakozik?
Előre is köszönöm.
Ottó
Hi, to all !
The oven Teka HL-870 do not enable heating elements.
The display, sensor keys, switches, funs are work.
When i connect the oven to power, the display show me few seconds "Sho on", then flashing 12:00.
I think this is "Demo Mode" for exhibitions.
I have read the instructions for this model, but did not see any information about enable/disable demo mode.
May be anybody have service manual for this oven to resolve this problem ?
RESOLVED!
In case of HL 870 ones, you must restart the oven and, until set the time, press the cooking time sensor and cooking stop sensor for 3-5 seconds. Then you can set the time and run the appliance without any problem.
Ez a főző E22 hibakódot produkál, majd tilt.
Tudnátok segíteni milyen jellegű hibát takar az E22?
Köszönettel.
