TOYOTA10-1-
CAR-AUDIO - OTHER
Type: (GIF)
1.5 KB
CAR-AUDIO
Looking for similar toyota manual?
    TOYOTA-101 TOYOTA101 TOYOTA 101 TOYOTA10
Suzuki Ignis Blaupunkt Dump
Egy 39101-86G10 Bosch /Blaupunkt Suzuki Ignis autó CD-hez lenne szükségem NO CODE-os Dumpra, ha esetleg lenne valakinek.
Köszönöm.
Vw autórádió kód beírása
A képen látható autórádió nem engedi beírni a kódot. Léptetni tudom a számokon a kurzort de nem engedi az OK-t.
Kód megvan hozzá, de a tulaj már próbálkozott a beírással.
Ha tápon hagyom magához fog térni?
Köszi
Balázs
Becker Cascade BE7944 need help!
Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
 I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Audi Concert II AUZ2Z3E fejegység nem működik
Üdv Mesterek !
Hoztak egy ilyen autós cd-s fejegységet.(AUZ2Z3E)Nem ad életjelet a villanyokat megkapja (régebbi a6-ban van).Nem találtam semmi mérhető hibát benne.Elképzelhető hogy csak akkor kapcsolható be ha benn van a busz körben ? Nem nagyon szoktam már autóhifit javítani. Ha valakinek esetleg van kapcsolasi rajza az is segítség volna.
Köszönöm.
