Tisztelt Uraim!
Van egy Lidl féle Supportplus URC-L 639 típusú távirányítóm, amit másik távról is lehet(ne) tanítani. Azonban FULL üzenettel válaszol. Reset-en túl vagyunk, helyzet ugyanez. Valakinek van tippje, hogy lehetne törölni az EEPROM-ját kiforrasztás nélkül? A válaszokat előre is köszönöm!
There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
Kaptam egy ilyen kamera rögzítőt, egy vagon kondi cserélése, meg HDD behelyezés után életre kelt, csak jelszava nem ismert. Gyári 123456-ot nem eszi meg. Leírásában nincs erre semmi megoldás.
Belül DVR408 szerepel a NYÁK-on, erre keresve klf. országokban más néven futott szerkezetről van szó.
Tud valaki okosat nekem? Jelenleg egy 4 csatornás van, de ha már így alakult, felbővíteném :)
Közben megkerestem 2 alkalommal is a Power biztonságtechnikát, tojnak a fejemre, válaszra sem méltatnak.
Nincs valakinek ismerőse náluk? vagy nem vásárol olyan halom cuccot tőluk rendszeresen, hogy nincs pofájuk elhajtani?
köszi!
Hello!
Kontakt hibával kezdődött, most már nem állítható a kapcsolási hőfok. A hőfokot azt jól méri.
Ha valakinek erről van infoja, rajz vagy valami? amiből lehetne javítani, az jó lenne.
A benne levő iC-k.
kijelző TL7107
komparátor TA324
multiplexer/demultiplexer TL4052BP
