Érdekes hibáról akarok beszámolni Nektek.
A fenti tévét bekapcsolva, előjön a raszter, van on-screen, de nem látja a jelt semelyik bemenetén (ant, scart, rgb, stb...).
Szétkapva, végre rájöttem, hogy az ic600 bemenete testzárlatos (rajz fenn a tanyán).
Ez egy kapcsoló ic (TPS2011A, power distribution switches, nem lehet kapni), valahova kapcsolja az 5V-ot (már nem kerestem hova).
És most jön a meglepetés (nekem):
A tévét bekapcsolva az említett ic nélkül, kifogástalanul működik!
Tapasztaltabb kolégák tudják, hogy lehet ez? Kérem, világosítsanak már fel (nekem már fáj a fejem).
Üdv:Robi
Hello everyone,
i am new to the forum and i would like to save a TV from the dumpster. I figured out that IC207 is broken on the mainboard of this TV. Does anyone have a schematic for these kind of TVs or even have the same and knows what IC this is? I presume it is a voltage regulator. The TV is totally fine but does not turn on any more. The power supply is perfectly fine. I desoldered this IC as it was getting very hot and was the only issue i found.
Thank you!!!
Choose the appropriate forum, then give it a title and enter your question.
The topic title contains the brand and type of the faulty device. It also briefly describes the problem.
e.g.: ACER AL1711 monitor screen turns off after 5 seconds
The incorrectly named topic will be suspended and then deleted after 48 hours! While suspended, others will not be able to comment until you correct the title!
The incorrect title can be corrected later (within 48 hours) by clicking on the "Edit" tab.
Request a drawing, service manual, via the "CLICK HERE" button in the "Search/WANTED" box on the right!
DO NOT ask for a car radio code in the forum!
If you are not familiar with electronics, DO NOT attempt the repair!!
You may even suffer a fatal electric shock! Contact a specialist!
Have you read it? - kalex moderator
--> I corrected it. Thanks for pointing out!
Kérdezném a sokat tapasztalt kollégákat, hogy annó ennél a kis tv-nél (LG ck14j70x 37cm) tapasztalták-e a következő hibát.
(Az aszony konyha TV-je....)
Bekapcsolás után a függöleges képméret kisebb, (alul felül kb. 3cm fekete) hang rendben. Kb 10-15 perc múlva elkezdi ::: pattogva villogva próbál a függöleges eltérítés meghalni. Recseg ropog de még nem halt meg csíkba. Pár perc hülés után újra él, az alap kisebb képpel. Amit lehet átnéztem, a melegedős részeknél mindent átforrasztottam, kifolyt vagy pupos kondit, égett ellenállást nem látok. Amit találtam itt rajzot, letöltöttem, de nem lettem okosabb. A következő opció a kuka, de hátha.
Minden ötletet megköszönök.
Jóska
Van egy JVC HV 32P40BU 82cm tv,hibája a következő:Bekapcsolás után világít a zöld led de kb 2 mp múlva kikapcsol(2 relé megszakítja a hálozatot) és visszaáll pirosra,a nagyfesz is megvan mert majdnem a kép is előjön.a táp szerintem jó,mert szekunderen a 150 volt megvan a többi feszülség is stimmel,a sorvégfok nem zárlatos szerintem ez is jó.Ha valakinek van valami ötlete,hogy mi lehet a baj,kérem írjon.
Előre is köszönöm!
FLY001
Kiigazítottam a topik címét.
Kalex
