UNAOHM GR23 VOLTOSCOPIO OSCILLOSCOPE-MM SCH
METER - SERVICE MANUAL
224.7 KB
METER
Looking for similar unaohm manual?
UNAOHM GR23 VOLTOSCOPIO OSCILLOSCOPE-MM SCH service manual (1st page)
Preview of UNAOHM GR23 VOLTOSCOPIO OSCILLOSCOPE-MM SCH [1st page]
UNAOHM GR23 VOLTOSCOPIO OSCILLOSCOPE-MM SCH service manual (2nd page)
Preview of UNAOHM GR23 VOLTOSCOPIO OSCILLOSCOPE-MM SCH [2nd page]
    UNAOHM GR-23 GR23 GR 23 MM
Relevant METER forum topics:
Oscilloscope UNAOHM G4020 = BECKMAN 9020 = Voltcraft_2040 - cinesc. is working - test the trigger - the dots UP and DOWN
Hi,
A friend offered Oscilloscope UNAOHM G4020 = BECKMAN 9020 = Voltcraft_2040
In first hours worked ok ...
I saw the 0,2 V 1000Hz and other signal in the cinescop.
But now I only see 1 or 2 dots (channel 1 or both or ch 2).
I can move the dots UP and DOWN, LEFT and RIGHT so the screen - cinesc. is working.
I test the trigger, connect CAL 0,2V 1KHz to ch 1 or 2 and the dot go up - down, invert, etc.
A sinos. wave, I can rotate TRIG LEVEL and the dot follow the wave.
But I can't see the wave in display.
Some examples of scope:
youtube.com/watch?v=3nBYp1pN40U
youtube.com/watch?v=fPq1KgQ5ggQ
youtube.com/watch?v=5osskamWJHg
Manual and schemat. I have the French and Germany version.
archive.org/details/voltcraft_Voltcraft_2040_Oscilloscope_Service_manual
https://elektrotanya.com/beckman-industrial_circuitmate_9020_sm.pdf/download.html
Can you please provide help?
Thank you,
Ruy
The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
Do not delete the moderator entry! If you delete again the thread in is closed permanently!
